ThingShield - ST Anything not working
Hi, I have used the ST_Anything_Alarm code to customize a device handler for my ThingShield. The code is below. When I run it in simulator mode with the hardware I get the proper responses for the individual sensors. However, on the APP all 9 sensors never change state. What am I doing wrong?
Thanks,
–Michael
  • ST_Anything_Alarm_Panel Device Type - ST_Anything_Alarm_Panel.device.groovy
  • Copyright 2015 Daniel Ogorchock
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
  • Change History:
  • Date Who What
  • 2015-12-06 Dan Ogorchock Original Creation
metadata {
definition (name: “ST_Anything_Alarm_Panel”, namespace: “ogiewon”, author: “Daniel Ogorchock”) {
capability “Contact Sensor”
    attribute "sensor1", "string"
	attribute "sensor2", "string"
	attribute "sensor3", "string"
	attribute "sensor4", "string"
	attribute "sensor5", "string"
	attribute "sensor6", "string"
	attribute "sensor7", "string"
	attribute "sensor8", "string"
	attribute "sensor9", "string"
simulator {
// Preferences
// tile definitions
tiles {
     standardTile("sensor1", "device.sensor1", width: 1, height: 1, canChangeIcon: true, canChangeBackground: true) {
		state("open", label:'CS1 ${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
		state("closed", label:'CS1 ${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
    standardTile("sensor2", "device.sensor2", width: 1, height: 1, canChangeIcon: true, canChangeBackground: true) {
		state("open", label:'CS2 ${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
		state("closed", label:'CS2 ${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
    standardTile("sensor3", "device.sensor3", width: 1, height: 1, canChangeIcon: true, canChangeBackground: true) {
		state("open", label:'CS3 ${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
		state("closed", label:'CS3 ${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
    standardTile("sensor4", "device.sensor4", width: 1, height: 1, canChangeIcon: true, canChangeBackground: true) {
		state("open", label:'CS4 ${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
		state("closed", label:'CS4 ${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
    standardTile("sensor5", "device.sensor5", width: 1, height: 1, canChangeIcon: true, canChangeBackground: true) {
		state("open", label:'CS5 ${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
		state("closed", label:'CS5 ${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
    standardTile("sensor6", "device.sensor6", width: 1, height: 1, canChangeIcon: true, canChangeBackground: true) {
		state("open", label:'CS6 ${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
		state("closed", label:'CS6 ${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
    standardTile("sensor7", "device.sensor7", width: 1, height: 1, canChangeIcon: true, canChangeBackground: true) {
		state("open", label:'CS7 ${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
		state("closed", label:'CS7 ${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
    standardTile("sensor8", "device.sensor8", width: 1, height: 1, canChangeIcon: true, canChangeBackground: true) {
		state("open", label:'CS8 ${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
		state("closed", label:'CS8 ${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
    standardTile("sensor9", "device.sensor9", width: 1, height: 1, canChangeIcon: true, canChangeBackground: true) {
		state("open", label:'CS9 ${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
		state("closed", label:'CS9 ${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
	main (["sensor1"])
    details(["sensor1","sensor2","sensor3","sensor4","sensor5","sensor6","sensor7","sensor8","sensor9"])
//Map parse(String description) {
def msg = zigbee.parse(description)?.text
log.debug “Parse got ‘${msg}’”
def parts = msg.split(" ")
def name  = parts.length>0?parts[0].trim():null
def value = parts.length>1?parts[1].trim():null
name = value != "ping" ? name : null
def result = createEvent(name: name, value: value, state: state, isStateChange: true)
log.debug result
return result
