Things I like BETTER about the new app vs Classic
someone was posting about Modern Forms recently
One update I don’t think was posted in here: Lighting Groups are now available in the new app. Currently can only control them manually, but I believe they plan to include them in scenes and/or automation creator eventually.
As discussed a little, there are also a lot of brands now that are only available in the new app due to them using the new cloud to cloud integration tools. Kasa, Yeelight, NexxHome, Sensibo, etc.
That’s a bad thing.
I would have to respectfully disagree, since they announced over a year ago that the V2 app was at end-of-life and would be discontinued eventually. There’s no reason to spend company resources maintaining the older option if you already know you’re going to discontinue it.
And this thread is about things that people like better in the new V3 app.
Complaints, discussions of design philosophy, etc. belong in the following thread instead:
"SmartThings Classic" vs "SmartThings (Samsung Connect)"
I respectfully disagree. When I made that initial post, I was looking for information, what I got, we’ll you know what I got. Anyway, just kidding @JDRoberts, but my intent was info.
I like that the new app loads 4x faster than the old app and the ability to put shortcuts to specific devices on my phone’s home screen. The search bar for the “all device” list is handy too.
So for a new install, would you all suggest using only the new app now since it’s been updated?
I wouldn’t but that’s me. It doesn’t currently (ever?) do everything that the classic version already does, so I have little desire to use it regularly until/if it ever does - or I’m forced to.
I would start with the new app. If you find a use case that requires Classic, then install classic and use both.
I agree with @Automated_House . :sunglasses: Start with the new V3 app. If it does everything you need, you’re all set.
If it doesn’t, you can also use The V2 classic app, but know that they have said it will be going away eventually, we just don’t know exactly when.
There’s a new easy to use timer and scheduling function directly on the device page for switches/bulbs.
You can now wipe your personal info from within the app settings
When creating scenes in the V3 app, adding a device to the scene adds it with it’s current settings. So this means you can go around manually setting up the devices how you want them, then create the scene and when adding each one they get added in their current state.
Just be aware that deleting your personal data is essentially the same as resetting the hub and wiping your account and you will not be able to use the hub again without again setting up a cloud account. That’s because it’s using the GDPR definition of “personal data“ which includes your location, your IP address, and any name that you have given to a device. See the following discussion:
Private Data Delete
The timer feature seems to be a one-time thing.
I briefly thought it could replace using the Power Allowance setting in Smart Lighting. It fired once and was gone.
The new apps’s SmartThings Home Monitor Security will return lights used in the Response section to their previous dim % when an alarm is dismissed. Switch state will not be returned.
Yep…just remember that max limit is 39 bulbs.
Ànd that’s the same three months later, strange behaviour?? Guess that has to be done in an automation then?
Bwaaaaahhhh No more Routines
