Struggling with capturing return of HTTP GET
Hi
Apologies for the basic query - I’m very new to this.
I’m using tguerena and surge919 's basic URI device handler as the basis of a new device type I’m trying to write, specifically an on/off switch for my BlueSound players.
It works as a stateless on/off switch, the device state ‘estimated’ by SmartThings based on the last thing it did.
However, I’d like to give the device handler refresh capability. That way, the device’s real status can be checked. I know the URI to get the info and how to plumb the return XML in other languages, but Groovy/SmartThings is fresh for me.
The current issue I’m having is when I call my HubAction via SendHubCommand, the Parse function is not being hit. What am I missing here?
Code as follows:
  • Author: tguerena and surge919
  • Device Handler
preferences {
section(“External Access”){
input “external_on_uri”, “text”, title: “External On URI”, required: false
input “external_off_uri”, “text”, title: “External Off URI”, required: false
input “external_state_check_uri”, “text”, title: “External State Check URI”, required: false
section("Internal Access"){
	input "internal_ip", "text", title: "Internal IP", required: false
	input "internal_port", "text", title: "Internal Port (if not 80)", required: false
	input "internal_on_path", "text", title: "Internal On Path (/blah?q=this)", required: false
	input "internal_off_path", "text", title: "Internal Off Path (/blah?q=this)", required: false
    input "internal_state_check", "text", title:"Internal State Check (/blah?q=this", required: false
metadata {
definition (name: “URI Switch”, namespace: “tguerena”, author: “Troy Guerena”) {
capability "Actuator"
capability "Switch"
capability "Sensor"
capability “Refresh”
// simulator metadata
simulator {
// UI tile definitions
tiles {
	standardTile("button", "device.switch", width: 2, height: 2, canChangeIcon: true) {
		state "off", label: 'Off', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff", nextState: "on"
			state "on", label: 'On', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821", nextState: "off"
	standardTile("offButton", "device.switch", width: 1, height: 1, canChangeIcon: true) {
		state "default", label: 'Force Off', action: "switch.off", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
	standardTile("onButton", "device.switch", width: 1, height: 1, canChangeIcon: true) {
		state "default", label: 'Force On', action: "switch.on", icon: "st.switches.switch.on", backgroundColor: "#79b821"
     standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat", width: 1, height: 1) {
		state "default", label:'Refresh', action:"refresh.refresh", icon:"st.secondary.refresh"
	main "button"
		details (["button","onButton","offButton","refresh"])
def parse(description) {
log.debug “HELLO!”
// log.debug “Parsing ‘${description}’”
// def results = []
// def result = parent.parse(this, description)
// if (result instanceof physicalgraph.device.HubAction){
// results << result
//def parse(String description) {
//log.debug(description)
def on() {
if (external_on_uri){
// sendEvent(name: “switch”, value: “on”)
// log.debug “Executing ON”
	def cmd = "${settings.external_on_uri}";
	log.debug "Sending request cmd[${cmd}]"
		httpGet(cmd) {resp ->
			if (resp.data) {
				log.info "${resp.data}"
if (internal_on_path){
	def port
		if (internal_port){
			port = "${internal_port}"
		} else {
			port = 80
	def result = new physicalgraph.device.HubAction(
			method: "GET",
			path: "${internal_on_path}",
			headers: [
			HOST: "${internal_ip}:${port}"
		sendHubCommand(result)
		sendEvent(name: "switch", value: "on")
		log.debug "Executing ON"
		log.debug result
def off() {
if (external_off_uri){
def cmd = “${settings.external_off_uri}”;
if (resp.data) {
log.info “${resp.data}”
if (internal_off_path){
def port
if (internal_port){
port = “${internal_port}”
} else {
port = 80
			method: "GET",
			path: "${internal_off_path}",
			headers: [
		sendEvent(name: "switch", value: "off")
		log.debug "Executing OFF"
		log.debug result
def refresh() {
if (external_state_check_uri){
	// sendEvent(name: "switch", value: "on")
	// log.debug "Executing ON"
	def cmd = "${settings.external_state_check_uri}";
			if (resp.data) {
if (internal_state_check){
	def port
		if (internal_port){
		} else {
			port = 80
			method: "GET",
			headers: [
log.debug "Executing REFRESH"
log.debug result
Return the hubAction object from each method when you want it to be called. I don’t think sendHubAction will work in a devideHandler without it. (In fact, I don’t think you need the sendHubAction call. Just return HubActrion.)
http://docs.smartthings.com/en/latest/cloud-and-lan-connected-device-types-developers-guide/building-lan-connected-device-types/building-the-device-type.html
“Herein lies an important point - if your HubAction instance is not returned from your command method, no request will be made. It will just be an object allocating system memory. Not very useful.”
