I believe the (133) is an error code. I havenāt been able to find what it means yet. Doesnāt help Iām on my phone and not at my PC right now. I may have had that error code along with another in my early efforts at getting this running.
I wonder if you try these switches
āsecurity-opt seccomp=unconfined
See my post around 108 and another user just after that. We had issues and this helped us get our containers to stay running.
Much later after I got this working. I created a new Pi boot SD. When I use that new sd card I donāt have to use those switches in my run command.
I redid my Pi boot SD card because I was having issues trying to also run some python scripts. Those issues also went away with a fresh setup clean boot SD card.
11/15/2022, 1:07:47 AM | HTTP server listening on port 8090
11/15/2022, 1:07:48 AM | SSDP server up and listening for broadcasts: urn:SmartThingsCommunity:device:MyQController
Found the controller in smartthings, entered creds, āawaiting credentialsā
And just to reiterate - if a moran like me can get this done, it says a lot about the average userās ability to get it done, ESPECIALLY with the help of all the knowledgeable people here.
Iād say from his experience and others, including myself, from before. If there was a way to know how old the version of the Pi OS is, it might be helpful to add the other items in the run command line.
Or possibly include that it needs to be a fresh install of the Pi OS using something like Pi Imager.
If so, possibly you could use another SD card and do a clean install on that. Hopefully your app settings and the rest wonāt need to be changed. It will just pick it up.
If not, then put old SD card back in.
Iād be curious if the more knowledgeable people in here have an option on that idea.
I just took the plunge and added the new version. Thank you for these steps. You made it really easy and It worked perfectly!
Also for anyone who read my earlier message about having both the door and the connector versions installed at the same time, the new install of myq connector did not create the doors until I deleted the original version of the doors.
I finally have my garage door discovered and showing on smartthings using the linux executable since my old spare laptop couldnāt run docker and my NAS docker is on a different vLAN than smartThings hub.
Now, is there a way to open the garage door by scanning an NFC tag? I had it running using iphone, webcore and the MyQlite app. Any help is greatly appreciated.
