The modification you sent does not work because of:
- When press the button on the power strip, a status message is received in the logcat, not a command message and therefore it does not execute the function “on, off handler”. Only switch 1 status updated in app
*********** press general button in device ********************
2021-09-15T09:52:37.807858082+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T09:52:37.816951749+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC174, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xAC, rssi: -57, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4F, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2021-09-15T09:52:37.832359749+00:00 TRACE Zigbee Multi Switch Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2021-09-15T09:52:37.837640416+00:00 INFO Zigbee Multi Switch Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2021-09-15T09:52:37.844479082+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> emitting event: {"attribute_id":"switch","capability_id":"switch","state":{"value":"on"},"component_id":"main"}
2021-09-15T09:52:37.863571416+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
- When you press switch 1 or activate with a scene in the app, a command is sent and therefore the "on, off handler" function is executed and the three switches are turned on or off.
*********** pushed "switch 1" on in app ********************
2021-09-15T09:56:03.247370847+00:00 TRACE Zigbee Multi Switch Received event with handler capability
2021-09-15T09:56:03.256782847+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> received command: {"positional_args":[],"component":"main","command":"on","capability":"switch","args":[]}
2021-09-15T09:56:03.262963847+00:00 TRACE Zigbee Multi Switch Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2021-09-15T09:56:03.270443514+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC174, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x01 >, < On || > > >
2021-09-15T09:56:03.283406180+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> emitting event: {"attribute_id":"switch","capability_id":"switch","state":{"value":"on"},"component_id":"main"}
2021-09-15T09:56:03.319916514+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC174, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x01 >, < On || > > >
2021-09-15T09:56:03.333332180+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> emitting event: {"attribute_id":"switch","capability_id":"switch","state":{"value":"on"},"component_id":"switch2"}
2021-09-15T09:56:03.375424514+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC174, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x01 >, < On || > > >
2021-09-15T09:56:03.393597514+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> emitting event: {"attribute_id":"switch","capability_id":"switch","state":{"value":"on"},"component_id":"switch3"}
2021-09-15T09:56:03.442634514+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T09:56:03.450842847+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T09:56:03.461276181+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC174, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC8, rssi: -50, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x57, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2021-09-15T09:56:03.482010847+00:00 TRACE Zigbee Multi Switch Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2021-09-15T09:56:03.489218514+00:00 INFO Zigbee Multi Switch Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2021-09-15T09:56:03.496397181+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> emitting event: {"attribute_id":"switch","capability_id":"switch","state":{"value":"on"},"component_id":"main"}
2021-09-15T09:56:03.511886847+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T09:56:03.518088847+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T09:56:03.526790181+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC174, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC8, rssi: -50, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7B, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2021-09-15T09:56:03.835019514+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T09:56:03.841309847+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T09:56:03.850178181+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC174, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC8, rssi: -50, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7C, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2021-09-15T09:56:03.865384514+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T09:56:03.871327514+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T09:56:03.880331847+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: faced48a-1d28-4a63-b543-7e08c5a182b8 [0xC174] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC174, src_endpoint: 0x03, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC8, rssi: -50, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7D, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
What I think happens:
- When the device is installed you see in the logcat the following steps:
- I don´t see in log “init”: the endpoints are assigned to the 3 components
- “added” is executed
- “doCofigure” is executed: attribute configuration and reports of the 3 components are sent, with min = 0 and max 0x12C (300sec)
***** doConfigure ********
2021-09-15T10:31:47.059171109+00:00 TRACE Zigbee Multi Switch Received event with handler device_lifecycle
2021-09-15T10:31:47.065263775+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received lifecycle event: doConfigure
2021-09-15T10:31:47.074557109+00:00 TRACE Zigbee Multi Switch Found DeviceLifecycleDispatcher handler in Zigbee_Multi_Switch
2021-09-15T10:31:47.080569109+00:00 TRACE Zigbee Multi Switch Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2021-09-15T10:31:47.099199442+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x00DB, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute ||
AttributeId: 0x0000 > > >
2021-09-15T10:31:47.140569775+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x00DB, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute ||
2021-09-15T10:31:47.158773775+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x00DB, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute ||
2021-09-15T10:31:47.190206109+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x00DB, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: EC1BBDFFFEAED9B9, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D97000204B680, dest_endpoint: 0x01 > > >
2021-09-15T10:31:47.219830109+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x00DB, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, minimum_reporting_interval: 0x012C > > > >
2021-09-15T10:31:47.257891442+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x00DB, dest_endpoint: 0x02, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: EC1BBDFFFEAED9B9, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D97000204B680, dest_endpoint: 0x01 > > >
2021-09-15T10:31:47.279568109+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x00DB, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, minimum_reporting_interval: 0x012C > > > >
2021-09-15T10:31:47.301488775+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x00DB, dest_endpoint: 0x03, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: EC1BBDFFFEAED9B9, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D97000204B680, dest_endpoint: 0x01 > > >
2021-09-15T10:31:47.328362775+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x00DB, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, minimum_reporting_interval: 0x012C > > > >
2021-09-15T10:31:47.410642776+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:31:47.501988442+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
- The 3 components respond as ConfigureReportingReponse || ZclStatus: SUCCESS>>> and emit event “off”
***** devices response ***********
2021-09-15T10:31:47.536992776+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T10:31:47.621316776+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x00DB, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC0, rssi: -52, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x52, ZCLCommandId: 0x01 >, < ReadAttributeReponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2021-09-15T10:31:47.762498109+00:00 TRACE Zigbee Multi Switch Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2021-09-15T10:31:47.888910109+00:00 INFO Zigbee Multi Switch Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2021-09-15T10:31:47.949163442+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> emitting event: {"component_id":"main","capability_id":"switch","state":{"value":"off"},"attribute_id":"switch"}
2021-09-15T10:31:48.260512776+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:31:48.326244109+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T10:31:48.356318443+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x00DB, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC0, rssi: -52, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x53, ZCLCommandId: 0x01 >, < ReadAttributeReponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2021-09-15T10:31:48.419551443+00:00 TRACE Zigbee Multi Switch Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2021-09-15T10:31:48.477431776+00:00 INFO Zigbee Multi Switch Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2021-09-15T10:31:48.498398776+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> emitting event: {"component_id":"switch2","capability_id":"switch","state":{"value":"off"},"attribute_id":"switch"}
2021-09-15T10:31:48.570318109+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:31:48.589026109+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T10:31:48.609388109+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x00DB, src_endpoint: 0x03, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC0, rssi: -52, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x54, ZCLCommandId: 0x01 >, < ReadAttributeReponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > >
2021-09-15T10:31:48.683783776+00:00 TRACE Zigbee Multi Switch Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2021-09-15T10:31:48.699154109+00:00 INFO Zigbee Multi Switch Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2021-09-15T10:31:48.713321109+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> emitting event: {"component_id":"switch3","capability_id":"switch","state":{"value":"off"},"attribute_id":"switch"}
2021-09-15T10:31:48.750909110+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:31:48.758937443+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T10:31:48.768531776+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x00DB, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xC0, rssi: -52, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x4A >, < BindRequestResponse || status: 0x00 > > >
2021-09-15T10:31:48.799564110+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:31:48.813861110+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T10:31:48.844891776+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x00DB, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC0, rssi: -52, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x55, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2021-09-15T10:31:48.873594776+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:31:48.879943110+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T10:31:48.896269110+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x00DB, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xC0, rssi: -52, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x4B >, < BindRequestResponse || status: 0x00 > > >
2021-09-15T10:31:48.924352776+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:31:48.930160110+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T10:31:48.960146110+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x00DB, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC0, rssi: -52, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x56, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2021-09-15T10:31:48.976503776+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:31:48.982416110+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T10:31:48.990866776+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x00DB, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xC0, rssi: -52, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x4C >, < BindRequestResponse || status: 0x00 > > >
2021-09-15T10:31:49.009021776+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:31:49.015726110+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee
2021-09-15T10:31:49.024145110+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x00DB, src_endpoint: 0x03, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC0, rssi: -52, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x57, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2021-09-15T10:31:49.041858110+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:31:49.048334443+00:00 TRACE Zigbee Multi Switch Received event with handler device_lifecycle
2021-09-15T10:31:49.071655776+00:00 INFO Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received lifecycle event: infoChanged
2021-09-15T10:31:49.081005776+00:00 TRACE Zigbee Multi Switch Found DeviceLifecycleDispatcher handler in Zigbee_Multi_Switch
2021-09-15T10:31:49.086969776+00:00 TRACE Zigbee Multi Switch <ZigbeeDevice: 10db2658-dd39-44ce-8ae4-2997e4312430 [0x00DB] (Lidl MultiPlug)> received unhandled lifecycle event: infoChanged
2021-09-15T10:31:49.097885443+00:00 DEBUG Zigbee Multi Switch Lidl MultiPlug device thread event handled
2021-09-15T10:32:16.915652790+00:00 TRACE Zigbee Multi Switch Received event with handler zigbee health poll
But only the main switch (1) sends the status changes messages according to the configuration sent.
I believe that this is the whole problem: The configuration has not been done correctly, since originallycode, without functions “on, off Handler”, driver execute the commands, but only the main switch respond to the state changes and reports configurated .
When you send a refrechs command, all 3 switches answer and update the status
I put the logs in case you see something that clarifies what is wrong.
I see something strange in the cluster 0x0021, cluster OnOff configuration, but I don’t have the knowledge to analyze if it is correct:
- In the configuration messages sent, at the ZDOMessageBody || < ZDOHeader the endpoint is always 0x01, although in addressHeader it puts enpoint 0x02 and 0x03.
It could be because it is always endpoint 1 that receives and transmits
