[ST Edge] Honeywell / Ademco Vista Panel - Envisalink
i need to redo or rethink my automations and virtual switch syncing for security states. anyone have a solid system they are using for that?
edit:
as a baseline, this is what I was originally using.
in the previous integration, the virtual switches and webcore pistons were needed to update STHM which couldn’t interact with STNP. virtual switches were also needed to work with Alexa.
i spent some time this evening reworking the routines a bit, and i think they’re mostly ready and functional, though i do need to do more testing. Using the STHM → Partition Integration option in the settings helps simplify things a bit, however while messing around in the Alexa app I remembered that I had installed the Eyez-On Skill which directly set up my Panel as a device within Alexa. Routines can even arm the system (but not disarm). Given that, I may be able to get rid of most of these routines altogether and possibly even the virtual switches. gonna play around some more
