Computer Host LAN v1.0.0-rc.1 - Release Candidate Available!
I’m happy to announce that Computer Host LAN v1.0.0-rc.1 is now available!
We’ve reached an important milestone: after several beta releases, extensive testing, and valuable feedback, we’re approaching our first stable release.
This release candidate focuses on the final improvements to installation, usability, and upgrade reliability. Rather than adding more features, we’ve concentrated on making the overall experience smoother and ensuring that existing installations can be updated without unnecessary configuration or disruption.
Download: Computer Host LAN v1.0.0-rc.1 - GitHub Release
Changelog - v1.0.0-rc.1 (since v0.5.6-beta.1)
Windows installer and user experience
- Improved the initial rendering of the installation wizard, particularly the Welcome and SmartThings hub discovery screens. This addresses an issue reported during Windows testing. Thanks, @TheHundredthIdiot !
- Improved hub discovery retries. If a subsequent search fails to find a previously discovered hub, the installer now preserves its selected IP address instead of forcing the user to start over.
- Manually entered hub IP addresses are also retained when another discovery attempt is unsuccessful.
- Improved error messages when an installation or upgrade cannot be completed, including clearer information about recovery.
Installation and upgrade reliability
- Corrected the post-installation health check to verify the actual packaged Windows agent version instead of expecting a hardcoded beta version.
- Improved consistency between the installer, agent versions, and release configuration.
- Expanded automated checks for beta, release-candidate, and stable versions to prevent version mismatches during future updates.
- Retained the existing upgrade and recovery mechanisms, including preservation of configuration, installation identity, authentication keys, and power-management preferences.
Release packaging and documentation
- Updated the Windows installation packages with version-specific instructions.
- Added a streamlined quick-start guide and an acceptance-testing checklist.
- Improved release verification and package consistency.
- All four automated testing workflows passed, including the Windows graphical installer, Windows agent, Linux agent, and complete release packaging.
No changes to the communication protocol or existing SmartThings capabilities are required. The integration remains fully local, using protocol v2.
Component versions
| Component |
Version |
| Computer Host LAN |
1.0.0-rc.1 |
| Windows Host Agent |
0.2.6-rc.1 |
| Linux Host Agent |
0.4.5-rc.1 |
| SmartThings Edge Driver |
0.4.5-rc.1 |
The updated Edge driver has already been packaged and deployed to the existing SmartThings driver channel. Version 2026-11-20T23:22:52
Installation and upgrading
Windows
Download the new windows-x64-unsigned-setup.exe from the GitHub release and run it as Administrator.
For an existing installation, simply run the new installer over the previous version. There is no need to uninstall anything, delete your SmartThings device, or pair it again. Your existing settings, device identity, and authentication key should be preserved.
For a new installation, the wizard guides you through SmartThings hub discovery, optional power management, and connecting the computer to SmartThings.
The installer remains unsigned, so Windows may display a security warning.
The Windows ZIP/PowerShell installation method remains available as an alternative.
Linux
Download the matching source ZIP or update your existing Git checkout. From the computer-host-lan directory, run:
./scripts/preflight.sh
./scripts/install-agent.sh --dry-run
sudo ./scripts/install-agent.sh
The existing installation identity and configuration are preserved.
The new Linux agent and Edge driver are already running successfully together on my Gentoo Linux system, with the existing SmartThings device continuing to operate normally.
Your feedback is especially valuable now!
We’re getting very close to Computer Host LAN v1.0.0, and this is where real-world testing makes the biggest difference.
If you’re already using a beta version, I’d particularly appreciate feedback on upgrading to the release candidate. For Windows users, I’m especially interested in whether the installation wizard displays correctly from the beginning, whether hub discovery works smoothly, and whether the existing SmartThings device continues operating without requiring any reconfiguration.
Of course, feedback on monitoring, service recovery, and optional power controls is welcome too.
There’s no need to run complicated test procedures. Simply installing or upgrading the RC and using it normally already provides valuable information. If something doesn’t behave as expected, please let me know which version you’re using and what happened.
A big thank-you to everyone who has tested the driver, provided logs, reported issues, or shared feedback so far. Your contributions have helped turn this project from an experimental integration into something that’s approaching its first stable release.
Unless we discover any significant problems, v1.0.0-rc.1 will hopefully be our final release candidate before v1.0.0.
Looking forward to your feedback!
