This mess started when liftmaster decided to ruin my garage door opener…
So I went out an bought a meross garage door opener. I installed it and it works fine from the meross app and from smartthings. usually once I have a device set up in smartthings I just tell google to sync devices and the new device in smartthings syncs over to google home. Then I can control that device with “hey google…”
I am just noticing that after telling google to sync devices it doesn’t sync the new meross garage door opener and also it doesn’t sync a couple lights I have from aidot. A bunch of other wifi services sync without issue.
Anyone have any ideas? I would really like to be able to say “hey google, open the garage door”. I know i can connect meross right to google assistant, but then I have to use a pin and I dont want to.
I tried that, but then I opened the door with voice control which turned the single virtual switch on and opened the door. But then my wife closed the door using the remote in her car. This left it in a state were the virtual switch was still on but the garage door was closed. The next time I tried to open the door the switch was already on and it didn’t work.
So I create two virtual switches and set the routines to open the door then “reset” the switch. So the next time google assistant used the virtual switch it would be in the correct state.
Does this make sense or am I making this much harder than it needs to be?
