SmartThings XBMC Home Theater Integration
Yeah… except I’d be a bit worried exposing my HTPC to the Whole Wide World.
@iGoControl
Authentication can be enabled for the EventGhost webserver as well, I just disabled it for my initial testing of the device type. Good call though, I should probably bake that into the device type code!
Curious as to if anyone has developed kodi integration further ? I run mine on a gbox q and would like to do basic stuff like dim lights when a movie starts. And When motion occurs only put lights to a certain level. Perhaps even set a mode to “Movie”.
I call a script from within Kodi to hit the endpoint URL for each action.
When a movie starts, the lights fade off.
I’m having issues with an endpoint that allows dimming to a set level though.
I’m not a developer, and I can’t figure out how to get the endpoint example to allow dimming with URL access to the device.
Someone tried to help me, but it didn’t work for me, and I haven’t revisited it yet.
Relevant code section for dimmers. This code snip allows you to send a value (1…99) to your dimmer.
 path("/dimmers") {
    		action: [
    			GET: "listDimmers"
    	path("/dimmers/:id") {
    		action: [
    			GET: "showDimmer"
    	path("/dimmers/:id/:command") {
    		action: [
    			GET: "updateDimmer"
You can find the whole example here
Was anyone ever able to come up with the code that would allow the device to update its state via Http requests?
