@kolosy, thanks for the update. This also corrected my issue for install as you suggested. I have updated the code to fix as well as modified images, version, and reference to provide payment for support due to lack of support by original author (this looks to be community owned now). Here is the link to my github for the code, hope this works for everyone.
I updated my code to give it a try and I am getting the error message below. I removed the ādefault: falseā. My error is slightly different in that the error line reports as 92.
groovy.lang.MissingMethodException: No signature of
method: physicalgraph.app.api.SubscriptionApi.subscribe() is applicable
for argument types: (java.lang.Boolean, java.lang.String,
java.lang.String, java.util.LinkedHashMap) values: [false, switch.on,
eventHandler, [:]]
Possible solutions:
subscribe(physicalgraph.app.DeviceWrapper, java.lang.String,
java.lang.String), subscribe(physicalgraph.app.InstalledSmartAppWrapper,
java.lang.String, java.lang.String),
java.lang.String, java.util.Map),
subscribe(physicalgraph.app.InstalledSmartAppWrapper, java.lang.String,
java.lang.String, java.util.Map), subscribe(java.lang.String,
java.lang.String, java.lang.String), subscribe(java.util.Collection,
java.lang.String, java.lang.String) @ line 92
Thanks. Thought I had done that but I guess not. Tomorrow will be the true test for me to see if I can start without using the IFTTT method. Fingers crossed.
What are you using to trigger it to turn on? This app just polls the roomba for status and if on it changes the SHM status to stay(arm) and then when off away(arm) it does not auto start cleaning. I use CoRE to start cleaning.
I have updated the DTH to 1.5.2 to resolve an error handling issue with error notification while Roomba is switching from docked to cleaning and cleaning to docked. Also added 2 new status updates for off and wait that I experienced today (also reduced errors).
Thank you for everything youāve done for this integration, I think itās about time you started your own thread that you control the first post since youāve very much made this your own now.
Thanks @Benji, I am ok with staying in this forum unless you guys feel we should start a new community thread for this redesigned version and ownership. I have also reached out to Thinking Cleaner to see if we can get the error number when it occurs on the device. I want to be able to provide error details when they occur.
My vote is for a new thread, the title is out of date anyway. I donāt want to create more work for you but I definitely feel this is your work now and any donations should be going to you instead, along with you having control over the very first post.
Let me know if Thinking Cleaner respond, Iāve emailed on and off with the guy over there (I think itās a solo effort) and heās been very helpful with some of the issues Iāve experienced with the module directly. He/They need to realise itās efforts like yours that are selling their modules.
I have added my Roomba to the Goodbye Automation however I am having a problem. The command is sent to the Roomba (confirmed by a beep) but the Roomba doesnāt start.
Alternatively, if I navigate thru the list of THINGS, find the Roomba, and try to use the CLEAN button, I get a beep. It is only after I press the CLEAN button again when the Roomba then leaves its dock to clean.
I replaced the code for the device type and handler from the new thread. Still have the issues that the roomba doesnāt leave the base.
Once I hit CLEAN, the roomba makes its startup sound but never leaves unless I hit clean several times.
Ideas?
Please visit the new thread for troubleshooting, the original thread creator is no longer offering support so the ownership/support have moved to the new threadā¦
