Ace2
(Chris Bell)
June 19, 2023, 3:35am
1
Noticed my zigbee network had issues and both my samsung plugs (6A-PL-Z-KO) no longer work, even removed 1 and re-added.
The logs show the last time they recorded something was the 28th May.
Anyone else having problems with these plugs??
The manual on/off button on the plug works and the edge driver in use is “Zigbee power switch MC”
Ace2
(Chris Bell)
June 19, 2023, 3:45am
3
I do have that every now and again with my aqara humidity/temp sensors.
A simple re-add gets those running.
But these 2 plugs will not reconnect at all, even removing device and re pair it wont work.
I rely on these two plugs to push the zigbee network around as well as 2 repeaters as well
Ace2:
There was a problem with the installation of a version at the end of May in some users.
Hi @Diegocampy
Some users had problems with updating old version of the driver.
Reinstalling driver solves the problem. I think so!!, since when some users have a problem they ask desperately, get a possible solution and then they don’t say anything about whether it is solved or not. I don’t care, but it would make it useful for other users to know if that is the solution to the problem
