Hello! I’m trying to write a Device type that allows for the control of my Spark Core which is attached to a 16-relay board. (The sole outlet of the GE duplex Z-wave outlets isn’t enough for my workshop
). Things are going well, but I’m noticing that sometimes the switches are left in limbo in the mobile app. So, let’s say I hit a relay to turn it off, it does indeed click off, but the status stays as “turning off”. I didn’t build the device type with polling and/or refreshing built in. Where would I insert this in the SmartThings device type? Would this resolve the problem? Should I use the response code sent by the Spark Core to accomplish this?
- Spark Core Relay Control
- Thanks to Jonathan Wilson and juano23@gmail.com
- Author: CMS
- Date: 2014-12-20
preferences {
input(“deviceId”, “text”, title: “Device ID”)
input(“token”, “text”, title: “Access Token”)
input(“outletNumber”, “text”, title: “Outlet Number (0-15)”)
// for the UI
metadata {
// Automatically generated. Make future change here.
definition (name: “Spark Core Outlets”, author: "christoph@scordinsky.com") {
capability “Switch”
// tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
main "switch"
details "switch"
log.error "This device does not support incoming events"
return null
def on() {
put outletNumber + ‘,HIGH’
def off() {
put outletNumber + ‘,LOW’
private put(relayCommand) {
//Spark Core API Call
httpPost(
uri: “https://api.spark.io/v1/devices/${deviceId}/relay”,
body: [access_token: token, command: relayCommand],
) {response -> log.debug (response.data)}
And for the Spark Core code:
int relayControl(String command);
int relay1 = D0;
int relay2 = D1;
int relay3 = D2;
int relay4 = D3;
int relay5 = D4;
int relay6 = D5;
int relay7 = D6;
int relay8 = D7;
int relay9 = A0;
int relay10 = A1;
int relay11 = A2;
int relay12 = A3;
int relay13 = A4;
int relay14 = A5;
int relay15 = A6;
int relay16 = A7;
int * relayArray[16] = { &relay1, &relay2, &relay3, &relay4, &relay5, &relay6, &relay7, &relay8, &relay9, &relay10, &relay11, &relay12, &relay13, &relay14, &relay15, &relay16 };
void setup()
//Initialize the relay control pins as output
Serial.begin(9600);
Spark.function(“relay”, relayControl);
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
pinMode(relay5, OUTPUT);
pinMode(relay6, OUTPUT);
pinMode(relay7, OUTPUT);
pinMode(relay8, OUTPUT);
pinMode(relay9, OUTPUT);
pinMode(relay10, OUTPUT);
pinMode(relay11, OUTPUT);
pinMode(relay12, OUTPUT);
pinMode(relay13, OUTPUT);
pinMode(relay14, OUTPUT);
pinMode(relay15, OUTPUT);
pinMode(relay16, OUTPUT);
//// Initialize all relays to an OFF state
digitalWrite(relay1, LOW);
digitalWrite(relay2, LOW);
digitalWrite(relay3, LOW);
digitalWrite(relay4, LOW);
digitalWrite(relay5, LOW);
digitalWrite(relay6, LOW);
digitalWrite(relay7, LOW);
digitalWrite(relay8, LOW);
digitalWrite(relay9, LOW);
digitalWrite(relay10, LOW);
digitalWrite(relay11, LOW);
digitalWrite(relay12, LOW);
digitalWrite(relay13, LOW);
digitalWrite(relay14, LOW);
digitalWrite(relay15, LOW);
digitalWrite(relay16, LOW);
//register the Spark function
void loop()
// This loops for ever
int relayControl(String command) { // syntax pinnum,ON
Serial.print("unparsed command rec’d: ");
Serial.println(command);
int relayNum = -1;
int relayState = 0;
char * params = new char[command.length() + 1];
strcpy(params, command.c_str());
char * param1 = strtok(params, ",");
char * param2 = strtok(NULL, ",");
//see what the parse job looked like
Serial.print("Param 1: ");
Serial.println(param1);
Serial.print("Param 2: ");
Serial.println(param2);
if (!strcmp(param2, "HIGH")) {
relayState = 1;
else if (!strcmp(param2, "LOW")) {
relayState = 0;
relayNum = atoi(param1);
if (relayNum >= 1 || relayNum <= 16) {
//write to the relay
Serial.print("relay "); Serial.print(relayNum); Serial.print(" "); Serial.println(relayState);
digitalWrite((uint8_t)*relayArray[relayNum], relayState);
if (relayState == 1)
return 1;
} else if (relayState == 0)
return 0
