Hubitat? say what now?
Been a thread on I for quite a while:
https://community.smartthings.com/t/hubitat-elevation-hub-home-automation-that-is-local/117107
repost from another thread…
Repeated again right above. And you didn’t even need to search yourself .
Does anyone know if the new app will support the V1 hub? I haven’t upgraded to V2 waiting for a V3 . Thanks
Some hope yet re custom device handlers…
“You will be able to access your SmartApps in the new SmartThings app. Custom commands and attributes, self-published devices, however, are not currently supported. We understand how important these features are to you, and are working to enable those in the new app. For now, you do not need to do anything. Use the SmartThings Classic app as usual. We will let you know when your features are ready to be transitioned to the new SmartThings app.”
I don’t know about the rest of you, but I am scared SXXT about how this is going to play out. As @tgauchat said, if SmartThings does this wrong it will cause an avalanche, which they will not be able to stop. They have to get their act together, as the way this thing has progressed is not good. And the amount or should I say lack of information and contact is appalling.
I didn’t say that.
I said that folks around here are presuming that SmartThings will get it wrong or are already getting it wrong, and also presuming that it matters to the greater strategic goals of SmartThings.
No avalanche is in sight.
Just some falling rocks for customers to avoid.
Question, I like to make small changes to DTHs and SmartApps to suit my personal use. A couple examples: I tweaked the color output on my Osram bulb to better match my other lights. And I edited in fake color temperature support to my SmartLife RGB controller so I could tell Alexa to set it to warm white.
Can I still do that in the new system? Or will I have to get changes approved to use them or something? Because playing around and tweaking stuff is one of the main fun and useful parts of SmartThings for me.
Though the new API is “just” in public Beta and incomplete in functionality, we’ve been told that personal publication will still be an option.
Widespread use of GitHub or other methods of distribution to other SmartThings customers will be discouraged, however; And to make up for that, the new “publication process” will be much more streamlined.
can you attach the smartthings hub to the new app, i can’t figure out how to do this.
edit: latest update looks like it added a hub icon
edit 2: can the hub be in both classic and new at the same time?
Yes. The Hub displays as a device in the new app and if you select it, it shows all connected devices to the hub.
So, device’s with custom DTHs will or won’t work?
They won’t yet. Which is one of the reasons we are telling people to continue with classic until all of the new developer tools are in place. There will be custom devices in the new app eventually.
oh damn, need the original code used to set up smartthings hub in new app? i got an replacement device from support… no idea where the card is now.
stop. do not proceed. you’ll need to wait for the migration.
Any suggestions?
Got my Welcome Code by calling ST support. Entered it in when prompted trying to connect my v2 Hub in the Samsung Connect (new) app.
Got a message displayed at the bottom of the screen when Register This Hub button pressed saying.
“Code already registered, Invitation needed from owner to use this hub”
Is this something to do with the account linked between ST and Samsung??? Not sure how to generate an invitation code???
Thoughts most welcome??
