Smart LED Tube?
I had the same results. There are a few Zigbee tubes I could find, but the profiles don’t match. (See FAQ: Zigbee Application Profiles, or why not all zigbee devices work with SmartThings).
So, I would say your best bet would be to use a non-dimmer smart switch.
(You’re probably aware of this, but just in case) A number of LED tubes require removing the ballast (which isn’t needed anymore in any case) and some require rewiring the “tombstones” so that neutral and line are at one end instead of opposite ends. If you’re in a location that doesn’t allow Do-It-Yourself rewiring or if this isn’t your thing, get in touch with an electrician.
