Smart blinds - Which to choose and do they play well with ST? [2021]
Hi,
I have been looking into buying motorized blinds. After a bit of research Somfy RTS seems the best choice. They should be working well with ST, but on the forum i mostly find people having problems with these.
Would Somfy be the best choice, and are there people who are using these without trouble?
Also i understand im going to need some kind of hub to change rts into zwave. Anyone with experience? Are they reliable? How is the range?
Any help would be very appreciated!
I prefer a ZWave shade instead of RTS. I got mine from ZebraBlinds. Mine are Graeber - which is just a brand name using Somfy / Springs Window Fashions / Bali ZWave motors.
I think you get the best integration with smartthings with one of three choices:
One) zebra blinds. As @nathancu Mentioned, these are zwave Devices , Based on the motors from other brands but put together into a custom package that includes smartthings integration. So adding them to a smartthings system is pretty simple and they’ve had strong customer support. There’s a company representative, @ZebraBlinds , Who is active in this forum and can answer any questions. They also occasionally post coupons here. :sunglasses:
  1. Ikea fytur. These are probably the least expensive smart roller blinds you can find. Zigbee. In the US they only come in one gray color, and in the EU I think you have a choice of two colors. Limited sizes, although you can trim in some cases if you need an arrow or one. They work, they’re cheap, they work with SmartThings. Not much more you can say than that.
  1. Lutron Serena. These use their own proprietary frequency, but do integrate with smartthings using the Lutron SmartBridge. Like all Lutron products they are really well engineered, have a choice of a lot of different colors and fabrics, battery life is great, and they are expensive. They typically go on sale twice a year, but that’s usually only a 10 or 15% discount. I like these, but I never bought them because of the price.
  1. Other brands with their own smartthings integrations. In the last year, about a dozen window coverings brands have added their own smartthings integrations which are available through the app. Choose the + in the upper right, then add a device, then buy device type, and you will find them under sensors, then window treatments.
This includes Bali and leviosa, along with some smaller brands. I haven’t seen much forum discussion of any of these other than the ones I previously mentioned, but you can ask in the forum and put the brand name in the topic title and see if anybody’s used them. You’ll probably need to check the manufacturers for more details. Note that just because the brand is listed, it doesn’t mean that every model works: for example, the SOMFY integration there is only for the Z wave models.
So as of this writing, January 2021, there are quite a few different ones to choose from. :sunglasses:
The only bad thing about ikea is there size, most definitely you would have to.cut the shade & top bar to fit your window. Your still spending a good bit of money for something that will not fit your window out of the box.
Also, if you want to consider curtains instead of blinds, here’s a recent discussion that includes that option.
Ideas/Suggestions needed (shades or curtains?)
Thanks for the tag @JDRoberts
Those are pretty much all the options.
@John010 to answer your questions, Somfy RTS is actually pretty solid. Once setup we’ve rarely heard of ongoing issues. The range on the bridges is around 60ft line of sight. Lower with walls. That said the main issue I have with it personally is:
  1. Somfy accessories are quite expensive
  2. RTS is an old RF protocol. And the bridges such as the ZRTSI or Mylink just act as an intermediary that processes open, close, and favorite position commands. It doesn’t let you move the shade to any spot you want, nor, show the current position in real-time.
If you feel home automation will always be there in your future I would look at the additional options JD posted above as well as our z-wave shades.
If you are interested I would check out our thread here: 2018 - Current: Custom Graber Virtual Cord Z-wave+ Shades & Bali Autoview Z-wave+ Shades
Thanks for the response. From all of the above Zebra seems the only one that would be suitable for me. Unfortunately im located in Europe…
IKEA should be available there. If you let us know why they don’t match your requirements, we might have some other suggestions for Europe. :thinking:
A lot has to be in custom sizes and designs. So i guess what i really am looking for is a blinds motor instead of the actual blinds. Somfy seems to offer everything that i need, plus they are supported by local guys who install things like that.
But im unsure about how well they actually work with ST. Its a big investment, plus its getting built into the house. So i do not want something that doesnt work well.
Coulisse Blinds - sold in US by SelectBlinds in EU by OmniBlinds amongst others. I’ve had one of their remote control (not smart) blinds for several years and it worked fine. Bought one of their smart blinds. It integrates with their “Eve” app easily allowing remote control from my iPad but not automation. So I bought a hub from https://www.robbshop.nl/ and had it shipped to USA. I have spent a lot of time trying to understand and here are my findings. Please correct my understanding if it is not correct. This spring I purchased 2 new Coulisse blinds. The first delivered was a CM-03-E, the second, a few weeks later was a CM-03. Apparently the CM-03-E is a new version. I bought the CMD-01 hub to try to automate these two blinds, but it appears that the new and old versions are not compatible ? See my table below. The CMD-01 hub integrates well with ST via cloud and I can schedule the CM-03 blind but not the CM-03-E
I highly recommend Automate by Acmeda. Their new Zero Motors are rechargeable so no electrician is need. they also have some patents which hide the antenna making it a more sleek look. you can check them out here:
This forum is for people who are using the Samsung SmartThings ™ home automation platform, so all of the questions and answers are assumed to be in that context. How would that product integrate with SmartThings? (Note that that is also specifically the topic of this particular thread.)
I see that you yourself appear to be either an employee or owner of the company at the site that you linked to. Vendors and manufacturers are always welcome to participate in the forum, but we do ask that they identify themselves as having a commercial relationship with any sites or products that they recommend.
Also, I see that that is an Australian company: do you provide your products to other regions? Do they have the same warranty and features there? Do they have FCC certification, which is required for use of any radio frequency product in the United States?
There are a couple of red flags about the site itself, including the fact that it’s obviously using a cookie-cutter site builder, and has not bothered to fill in all of the pages.
One of the big concerns in the home automation industry globally is tiny companies which go out of business within a year or two of sales and the products then no longer function. How long has this company been in business?
Again, we do welcome people who have a commercial interest in what they’re recommending, that just needs to be disclosed. And for this forum, it needs to be something that can work with the Samsung SmartThings home automation platform.
one small technical point: the site claims that only their own product and Somfy provide two way communication for home automation. That’s not true. There are many smart blind products that have two way communication these days, at least in the United States and the EU. I’m not familiar with the Australian market. But certainly Lutron, Z wave and Zigbee motors, switchbot, and a number of other options have the kind of two way communication the site describes. But again that may be a regional issue.
