I am interested in the design you setup can you share the PDF? Thanks
I just installed this and can’t figure out how to turn it off From the app. How do you do it? And there’s no timer setting in this app. It has to be a scene?
Really late post but we had a certified electrician install an outdoor outlet next to our pool pump, sits on a post above 1.5’ above the ground, maybe 2’ away form the pump (24’ above ground) and then plugged the pool pump into an outside smart outlet. We set the timing on the outlet. Works great and is much safer.
If you can find it, the Intermatic InTouch CA3750 Contactor Module is much cheaper and works great. That’s what I used for my pool pump. Has been very reliable as far as turn on/off although at very cold temperatures, the status reporting has sometimes been delayed.
