Hi,
When building a smart app, if you want to select lights, you have a section like this:
section("Turn these light on") {
input "switch1", "capability.switch", title: "Turn on...", required: true, multiple: true
Is there an easier way to select lights that have been grouped; i.e. on my SmartThings iOS app dashboard I have “Lights and Switches” and all my lights in the Dining room are grouped to “Dining room”. I find it annoying that I have to select 12 lights individually each time I want an action of lights.
I use LiFX Bulbs with the following Types and App code; when sending a command to my lights it sends a command one by one; so to turn on 12 bulbs takes about 12 seconds; being able to send a single command to LiFX API for the group of bulbs would mean all bulbs in that group turn on at the same time.
https://github.com/zzarbi/smartthings/blob/master/app/lifx/lifx-connect2.groovy
https://github.com/zzarbi/smartthings/blob/master/device/lifx/lifx-bulb-2.groovy
Any help would be greatly appreciated and I thank you in advance.
Regards
Barry
