How can I convert in the device handler temperature readings.
It’s an external thermometer on a water tank and tops out at 50degrees C. I expect and will test that is about 85 degrees.
Now it might be an offset I need but I might need to scale it every so often. So 20degrees is a different offset to 25 or 30.
Thanks.
