It seems that this is only available on K(KS/KU) 2016 for series 6,7,8,9.
Well, I can perfectly control kodi through Smartthings (thereās a specific thread on that) and I will search for some IFTTT services which might run on my Samsung Smart TV. I am just not very hopeful because the J-series doesnāt run a very flexible operating system, hence apps availability is reduced. Thanks for the swift reply.
I canāt link the TV to ST⦠Iāve tried everything⦠Even unplugging the TV, Router and hub as instructed by Support⦠What can I try?
In order to link your TV with SmartThings, the model of TV has to start with XXKU for example.
Samsung 55KU6402
Samsung 49KU6402
Samsung 40KU6402
Samsung 32KU6402
The number 32/40/49/55 etc in the front of the model represents the number of inches.
sh*t⦠so no KS8000 like it was advertised in the past?
From what I know, for the moment, the KS series āworksā only in America and only with an extra USB dongle. With that dongle the TV became a SmartThings hub.
So you can not link a TV from KS model directly to a ST hub.
f#ck, f#ck, f#ck, f#ck⦠I bought this TV specifically because ST told me⦠but I live in Spain! Not USAā¦
Go quick the TV back and buy a KU model.
LOL! Iād do it⦠if I had a time machine and go back to 11.5 months ago!
Then sell it and buy a KU⦠
(sorry man.)
How does it work? is it wifi? is it zigbee? does it need a smartthings hub in the same network?
The ST Extend did work on the KS TVs. I know as I had it working.
Then Samsung updated the firmware to stop it working. And another kick in the goolies,
is that ST and Samsung has stopped the smartthings hub from seeing the TV and vice versa.
Iām in the UK by the way. https://www.theverge.com/2017/10/31/16585788/samsungs-chronic-failure-to-deliver-on-smartthings-tv-promises
I read that a KS TV + SmartThings Link is a SmartThings hub replacemanent. So, also ZigBee and Z-Wave. But Z-Wave is on another frequences in America.
In your place Iāll sell that TV and buy a KU one.
According to support, they confirmed this is broken currently when I contacted them.
Thanks for reaching out and we apologize for the delayed response! I 'm sorry to hear about your TV not discovering; it is definitely a compatible model.
Unfortunately, after a recent firmware update, these TVs have not been discovering. We are aware of the issue and are working on a resolution. At this time there is not a definite timeline. If you would like, I can keep an eye on this and follow up when we have a resolution, please just let us know.
Well they said to me they done a fix just after the update. And that was supposed to sort it out. But it never did.
The UK firmware dept doesnāt know if there will be a fix.
Samsung are not saying a word about this.
In other wordsā¦Donāt say a thing and hope they go away.
Are you talkin about KS series of TV? (not KU)
Yes the KS TVs. I did say
In the instructions this is not clearā¦
First, power ON the TV and connect the TV to your local network, if you havenāt already. The TV must be on the same network as the SmartThings Hub to connect with SmartThings.
I have hub (Samsung Connect Home), this hub is connected via LAN to Router right, to have internetā¦
but in the instructions said āthe TV must be on the same network as the SmartThings Hub to connect with SmartThings.ā What WiFi network: Wifi Router? or Wifi Smarthings Home Hub?
Becuase in both cases after add manually and wait during 15 minutes waiting the phone never found the TVā¦
I have this model UN50KU6000KXZL⦠Could you help me if in TV need to enabled some option to connect with smartthings app. please if have any video to connect TV with Smarthings please share with us thanks
You will not be able to use the TV with SmartThings in the SmartThings app.
You should be able to add it in the Connect app though:
https://www.samsung.com/us/support/answer/ANS00062922/
Any chance we can then connect smartthings AND Samsung Connect together?
