Hi Brian.
Give this a try. You will create 3 rules and 1 virtual switch
Step one - Create a virtual switch named “Party Disable”
Step two - create these rules:
Rule Name - Storm Door Notify
Conditions - Storm door open
Rule - Storm door open
Actions for true - Notify: “Activity at front door”
Actions for false - Leave blank
Switch to disable rule - Turn on: Party disable switch
Rule Name - Front door open first
Conditions - Front door open
Rule - Front door open
Actions for true - Set private Boolean of Rule “Storm Door Notify” to false
Actions for false - Set private Boolean of Rule “Storm Door Notify” to true
Rule Name - Presence turns off Doorbell Rules
Trigger - Presence sensor arrives
Actions - Set Private Boolean of Rule “Storm Door Notify” to false
What all of this does:
Rule - Storm Door Notify - This rule will send you a notification or push message when the storm door opens.
Rule - Front door open first - This rule will disable the storm door notifications when the front door opens and it will enable the storm door notifications. This is because if you are leaving the house, the front door is opened first. If someone is outside going in, the storm door is opened first.
Rule - Presence turns off doorbell rules - this rule disable the storm door notification rule when you arrive home. The rule is enabled once you open and then close the front door.
Scenario - Someone opens the storm door to knock or leave a package - you are notified.
Concern - This rule will do nothing if the storm door is not opened.
Solution - Put a motion sensor on the porch and incorporate into rules
Scenario - Front door left open for sunlight or whatever. Someone opens the storm door. No notification
Concern - What if someone walks up and comes in, you will not be notified
Solution - Buy a Chihuahua
Scenario - You leave the house. You open the front door first, then the storm door. No notification
Concern - None
Solution - None, this is what you want it to do.
Scenario - You arrive home from work. You open the storm door to go in, no notification sent. Once the front door is opened and then closed the notifications are restarted.
Concern - None
Solution - Just something extra cause I’m awesome
Scenario - Kids are running in and out and your phone is blowing up with notifications.
Concern - You go crazy and drown the kids.
Solution - Open app and turn on the “Party Disable” switch
Once you set this up and test it please let me know if you have any questions, concerns, glitches, or whatever… I’d like the feedback so I can tweak the rule. I keep these and add them to my database of rules.
