Rule Machine - Get peer assistance here with setting up rules
I can’t get into the app right now to build this but you should be able to do this with one rule.
You set this up as a Rule not a Trigger correct?
Do you have the virtual switch on in the TRUE action? Then set the virtual switch to off in the FALSE action.
Can you post a screenshot of the rule?
This should really be moved to this thread:
