Nice addition.
Calling it “4way” is a little confusing - initially thought this related to multiple-switches controlling one output. Now I see this devicehandler is Switch+Level+Contact+Motion, which makes Alexa integration simple.
Nice addition.
Very true; what do think would be a more appropriate name?
Just suggesting
“Alexa Virtual Switch or Virtual Dimmer”
Personally, I would probably call it a “4 capability Alexa Virtual Device (Contact Sensor/Switch; Motion Sensor/Dimmer)”, but that might be too technical for most people.
Thank you @ero4444, @dotan_shai, & @JDRoberts for your naming suggestions!
I have renamed it to Stateless 4 Capability Alexa Virtual Device
Were you able to make the routine work? I have the same issue here. I am located on Mexico. I wonder if there is an issue based on the locale. Are you also outside US or UK?
juan
Just tried setting this up and having an issue where I can select the “contact sensor” as a trigger in Alexa routines and the state switching is working (when I turn the switch on in smartthings, it shows as on in Alexa) but routines are not getting triggered.
Anyone have a solution? Using the new skill.
Edit: Just checked, my contact sensor is displaying as a switch in the Alexa app. However, I can also select it for use as a contact sensor in the “when” section in routines but the routine doesn’t trigger when the contact sensor is opened.
I’m going to try these newer device handlers in this thread, but here’s an old one (below) that I’ve been using. Too bad the built-in SmartThings ‘Simulated Contact or Motion Sensor’ doesn’t do what we need, because I can manually trigger them in the old SmartThings app.
I’ve been using the Mike Maxwell uDTH for a long time which still works. However, it has a visual glitch when viewing its device page in the new SmartThings app, and it doesn’t allow manually toggling it in the new SmartThings app device page even though Automations can toggle it so it does basically work. I can manually toggle it using the old SmartThings app so that I can test the Alexa Routines using it.
(link removed)
UPDATE: I just tried the Simulated Alexa Switch DTH in this thread and it works fine in the new SmartThings app. It visually looks good and I can manually toggle it and use Automations to toggle it too. Nice!
Sounds like you are having the same issue as many others of us… we’re still waiting on feedback.
I’m now using this ‘Simulated Alexa Switch’ and so far it’s triggering my Alexa Routines just fine.
In my case, I’m using the new Alexa skill, but when I first started using it a few months ago, I wiped everything in Alexa in the web and started the new Alexa skill fresh since I wasn’t using any Alexa Routines in the old skill anyway. And these new Alexa Switches are freshly created too since I just started using this device handler the other day. So far two Simulated Alexa Switches that I have created are triggering the three Alexa Routines I have configured using them which are being initially triggered from SmartThings Automations.
UPDATE: I had the STHM false trigger today since I was including all sensors. These Alexa Switches appear to the STHM as open/close sensors so I have now excluded them in the STHM.
Super DH but now when I migrate to the new Smarthings App, the created virtual devices do not show up. Pretty annoying. Anybody else have this problem?
Hi, im new on here but have been using the simulated switch for a while now, only problem is as of tuesday just gone none of the triggers for motion, contact or simulated operate anymore, from the testing ive done im convinced its a problem with the smartthings skill on Alexa, do you guys in the know agree with this, Ive found i can see the trigger from smartthings open and close in the elexa app but since tuesday no longer operates it, Ive also been on to tec support on amazon but they seem to think its the device, i have a dot and show and both stopped working at the same time, ive even tried setting up a temp alexa account to see if that cured it, intersted in your comments cheers Dave
Hi @uncledaveghr. Welcome to the group!
SmartThings engineers are aware of the problem, and as far as I know, working on a solution. It doesn’t seem to be affecting everyone, but there are a few threads with folks talking about it.
I added a new device of this device type today. It shows up in the new app fine. But once it was used, the contact sensor part and the switch part no longer remained in sync.
Here you can see the switch is off, but the contact sensor remains open.
The elexa echo came back online around 17:00, it last about an hour then off again, will keep you posted on any updates.
I’m using the Switch version and not the Button version of this Virtual Alexa device handler so it doesn’t show the momentary standby option. The switch version has been working fine since I installed it. Alexa Routines are being triggered by it, and I even set the Alexa Routine to turn it off when it runs so that the Virtual Alexa Switch can be triggered again later in various SmartThings Automations.
OK, I tried the switch version instead of the button version and it is working in the new app. I haven’t tried it with Alexa routines yet.
I normally set mine up with the power allowance feature so they turn themselves off after one minute and then they are available for reuse.
Is it the bjpierron ‘button’ (it is a long thread)? That is what it does. Nothing in the device handler shuts the contact. The open event is sent with ‘isStateChange’ true so it always propagates in the Classic environment. I’m not sure exactly how that interacts with subscriptions in the new apps as the API includes a state change boolean as an option.
I found out something interesting -
I went to @bjpierron’s GitHub repository and found code for a “Virtual Alexa Switch”.
[Commits · bjpierron/SmartThings-Alexa · GitHub]
I have been using his older code for the “Simulated Alexa Switch”.
I updated my DTH in the Groovy IDE and the new device handler hangs up in the new Smartthings app when I try to open the contact…
I went back into Groovy and put the older code I had for the Simulated Switch and everything works normal.
Note: I can’t seem to find the exact code in his repository
EDIT: my device handler code is exactly what is in the first post of this thread…
Not sure why and don’t plan on trying to figure out why, but interesting anyway!
Hi, alexa started working again around 2 this morning UK as it switched the lights on from a ewelink switch from the new type Smartthing motion sensor and still working 8 hours later, maybe the skill has been sorted now
