I got the alarm working!
The responses to things like what time is it and whats the weather have a neat echo throughout the house, but otherwise its fine.
Great to hear!
The broadcast echo can’t be helped; the protocol apparently doesn’t synchronize time unlike Chromecast groups. Perhaps they’ll fix it in the future.
hello i’ve been trying to get the (what looks like a great app) google assistant helper to work today, and i’m almost there but there is no sound… i get to this point
info: Received request “What time is it”" for user global.
info: Text response from Google Assistant.
{ conversationCounter: 11, text: ‘The time is 2:54.’ }
info: Broadcasting content of text response
info: Received request “broadcast The time is 2:54.”" for user global.
silly: Receiving audio-data frame
{ conversationCounter: 11, audioDataFrameLength: 1600 }
debug: First frame of audio data - Initializing.
{ conversationCounter: 11 }
silly: Received audio-data frame.
audioDataFrameLength: 1600,
audioDataTotalLength: 1600 }
etc…
so it seems to be constructing the audio response but it doesn’t send it to the google home.
any ideas ?
The most salient part of the log is going to be the end of the response (when all the audio frames have been received). Can you put this in a pastebin somewhere so I can look at it?
thanks for your quick response ! here is the end of a broadcast request.
{ conversationCounter: 1, audioDataFrameLength: 1600 }
silly: Continuing audio-data
audioDataTotalLength: 60800 }
{ conversationCounter: 1, audioDataFrameLength: 346 }
audioDataFrameLength: 346,
audioDataTotalLength: 61146 }
debug: Conversation ended.
{ conversationCounter: 1 }
and when i started up the program it recognized my google home
Found service.
Hm… I’m not getting enough context here to figure out what the issue is. Can you do this? Start the program from scratch, try to send a single broadcast as you have done, then PM me the entire contents of the logfile? You can redact any information you think is sensitive.
Yes here it is -
debug: Logger initialized
debug: Binding POST route for /broadcast,/broadcastAudio,/custom,/chromecastAudio,/chromecastTTS,/blahblah,chromecastControl
debug: Binding GET route for /broadcast,/broadcastAudio,/custom,/chromecastAudio,/chromecastTTS,/blahblah,chromecastControl
debug: Binding all route for *
info: Starting external relay server.
info: Relay online.
info: Starting internal media server endpoint.
info: Configuring media static app to whitelist IPs
{ staticServerWhitelist: [ ‘blahblah’ ] } ----- i set this to the Google Home
info: Media server online.
info: HTTP Server created on port 2001.
info: Static server started on port 25000.
info: Found service.
{ serviceName: ‘Google-Home-Mini-blahblah’,
friendlyName: ‘blahblah’,
address: ‘blahblah’,
port: 8009 }
info: Adding service “blahblah”.
debug: Creating assistant for user public.
info: Assistant for public ready.
debug: Creating assistant for user bedrooms.
info: Assistant for bedrooms ready.
debug: Creating assistant for user global.
info: Assistant for global ready.
info: Received request: command: “Hello world”, user: public, relayKey: [Redacted], delayInSecs: undefined
info: Sending “broadcast Hello world” for user public.
info: HTTP POST /broadcast
{ res: { statusCode: 200 },
req:
{ url: ‘/broadcast’,
headers:
{ host: ‘localhost:2001’,
‘user-agent’: ‘curl/7.52.1’,
accept: ‘/’,
‘content-type’: ‘application/json’,
‘content-length’: ‘117’ },
method: ‘POST’,
httpVersion: ‘1.1’,
originalUrl: ‘/broadcast’,
query: {} },
responseTime: 2 }
info: Received request “broadcast Hello world”" for user public.
{ conversationCounter: 0, audioDataFrameLength: 1600 }
{ conversationCounter: 0 }
audioDataTotalLength: 3200 }
audioDataTotalLength: 4800 }
audioDataTotalLength: 6400 }
audioDataTotalLength: 8000 }
audioDataTotalLength: 9600 }
audioDataTotalLength: 11200 }
audioDataTotalLength: 12800 }
audioDataTotalLength: 14400 }
audioDataTotalLength: 16000 }
audioDataTotalLength: 17600 }
audioDataTotalLength: 19200 }
audioDataTotalLength: 20800 }
audioDataTotalLength: 22400 }
audioDataTotalLength: 24000 }
audioDataTotalLength: 25600 }
audioDataTotalLength: 27200 }
audioDataTotalLength: 28800 }
audioDataTotalLength: 30400 }
audioDataTotalLength: 32000 }
audioDataTotalLength: 33600 }
audioDataTotalLength: 35200 }
audioDataTotalLength: 36800 }
audioDataTotalLength: 38400 }
audioDataTotalLength: 40000 }
audioDataTotalLength: 41600 }
audioDataTotalLength: 43200 }
audioDataTotalLength: 44800 }
audioDataTotalLength: 46400 }
audioDataTotalLength: 48000 }
audioDataTotalLength: 49600 }
audioDataTotalLength: 51200 }
audioDataTotalLength: 52800 }
audioDataTotalLength: 54400 }
audioDataTotalLength: 56000 }
{ conversationCounter: 0, audioDataFrameLength: 1552 }
audioDataFrameLength: 1552,
audioDataTotalLength: 57552 }
info: Conversation ended with audio content; broadcasting.
debug: Sending initial “broadcast” message to preface audio
{ conversationCounter: 1, audioDataFrameLength: 1138 }
audioDataFrameLength: 1138,
audioDataTotalLength: 52338 }
debug: Conversation ended with invitation to continue.
debug: Have audio buffer to continue conversation; sending.
info: Sending audio in response to continued conversation.
{ conversationCounter: 1, audioDataTotalLength: 56882 }
silly: Sending frame; indexes 0 to 16000 of 56882
silly: Sending frame; indexes 16000 to 32000 of 56882
silly: Sending frame; indexes 32000 to 48000 of 56882
silly: Sending frame; indexes 48000 to 56882 of 56882
debug: Sent 56882 bytes.
debug: Received end-of-utterance.
silly: Received intermediate transcription.
transcriptionResult: { transcription: ‘got’, done: false } }
transcriptionResult: { transcription: ‘Gary’, done: false } }
transcriptionResult: { transcription: ‘got it’, done: false } }
transcriptionResult: { transcription: ‘got it brought’, done: false } }
transcriptionResult: { transcription: ‘got it broadcast’, done: false } }
transcriptionResult: { transcription: ‘got it Broadcasting’, done: false } }
transcriptionResult: { transcription: ‘got it broadcasting now’, done: false } }
debug: Received completed transcription.
transcriptionResult: { transcription: ‘got it broadcasting now’, done: true } }
{ conversationCounter: 1, audioDataFrameLength: 1552 }
i just sent it (with some redundant things taken out of the middle for length) but it doesn’t show up probably because it is too long.
this is what i used to test it
curl -H “Content-Type: application/json” -X POST -d ‘{“command”: “Hello world”, “user”: “public”, “relayKey”: “blahblah”, “broadcastAudioResponse”:“true”}’ http://localhost:2001/broadcast
i’ve looked for your PM but can’t find it…
I’ve PMed you, just reply to it.
