The dehumidifier I have has a pretty poor humidity sensor, which results in it running quite often. Does anyone have any recommendations for an accurate humidity sensor? I’m thinking about the Zooz ZSE40 4-1. Any other suggestions?
Naturally I’m going to use a smart outlet with my dehumidifier and turn it on and off based on the humidity sensor.
I use this one and have had good luck with it. The zooz was not available, and the Aeotec’s driver is native in ST. Downside is you need to buy batteries or plug it into a USB,
The Zooz was not out when I bought it. I would consider the Zooz but the way it reports lux (in percentage) is not standard. Not sure if it will work with rules.
Mine was within a percent of the only other reference I had, albeit not a precision reference. Have three currently installed at two locations/hubs. Seems OK for “relative” humidity!
There is Aeon if you want zwave, which @desertblade mentioned and then there NYCE ceiling if you like zigbee. I have both and they work well. A NYCE variant is used by Control4.
Sorry to break it to you, but you just got yourself in a nightmare. I meant to warn @Bjomesphat , that had a hell of a time trying to pair one couple of weeks ago. And I have 150+ devices. I ended up using a custom handler.
I used a custom handler at first, but went back to the stock handler.
Here is what I did awhile back:
Delete all the custom device handlers you have and unpair the device. Reset the device:
“At some stage or your primary controller is missing or inoperable, you may also wish to reset all of your MultiSensor’s settings to their factory defaults. To do this, press and hold the Z-Wave Button for 20 seconds and then release it. Your MultiSensor will now be reset to its original settings, and the LED will stay solid for 2 seconds and then turn off as a confirmation.”
Then re-add it to smartthings using the default device handler that shows up.
Do a general exclusion first. Then reset the device. Try the stock option like @desertblade said. But if that doesn’t work, or your sensor doesn’t show the motion capability but picks up on the others (that’s what happened to mine) then use @erocm1231 handler. I had no problems with it since I paired it.
