There are a few posts that had links to an older version on Github. This link is the one to use:
Thanks for all your hard work Mitch. This seems to be working for me. The only odd part is mine is reporting -16% battery. Thatās negative sixteen percent. I read most of the thread and saw issues with battery levels not reporting at all but it wasnāt clear to me if there were issues with levels being reported incorrectly. It doesnāt really matter to me too much (what the battery level is) but itād be nice to know before my sensor dies.
Thank you Mitchā¦ I had to install 2 more trippers and this code worked without all the trouble.
I had trouble finding a good range for battery levels. Mine basically stopped being useful around the 2.3-2.4v range. Missed messages, etc. That was on the original Tripper firmware though and with a fairly marginal ZigBee mesh. Later firmwares increased my battery life by a substantial amount and Iāve strengthened my network quite a bit. I might need to redo the battery scale similar to how ST has theirs now. Itās not quite a linear scale.
Edit: Iāve updated the handler with battery code that might (hopefully) provide a better estimate at battery levels.
I am new here, so how do I get your updated code? I think I have github integration in the ST turned on, and linked to your repo. Can I just pull in the latest code from there?
Update: figured it out!
Is there any way to check the firmware version or update it?
They can be updated by connecting them to a Wink hub. There is no way to update them using ST.
thatās what i didā¦ I first paired them with a Wink Hub, rebooted my Wink hub to force the update, unpaired and then paired with ST
Hello everybody Iām new to the smartthings community. I have a few quirky Tripper that Iām trying to add to my smartthings but the status is just stuck to open and wonāt do anything else. I tried removing the battery put it back and run pairing but nothing. Can someone please help me. Iām using thedevice handler linked above by @mitchp
What is the latest firmware? Hooked one up to a Wink Relay and it says 1.8b00/5.1b21
Iām having issues pairing these Quirky trippers. I currently have 3 of these with no issues whatsoever that I installed a long time ago. Iāve got about another 10 of these that I have had in storage. I decided to go ahead and start to install them, but they wonāt pair at all. Iāve tried pairing with an older version of MitchPās code. I then updated the IDE code, and tried to pair with no success. Considering I have a ton of these sensors I would love to get these working. Any suggestions? Thanks!
Thatās the latest code for the trippers
You may have to pair them with a wink hub or relay first to update their code. Also try new batteries. The ones included with the trippers are bad and donāt provide enough power after a few months in storage.
Never mind figured it out after going through the whole thread and went on to create the device handler instead of the smartapp ! Thanks again for all your work.
Hi @mitchp,
Thanks for all your help on creating the custom app and answers on the thread. I tried using the code at https://github.com/mitchpond/SmartThingsPublic/blob/master/devicetypes/mitchpond/quirky-wink-tripper.src/quirky-wink-tripper.groovy and receive the following errror?
No signature of method: script14747682287281365405569.metadata() is applicable for argument types: (script14747682287281365405569$_run_closure1) values: [script14747682287281365405569$_run_closure1@32bffa2e] Possible solutions: getMetadata(), getState(), setState(java.lang.Object), metaClass(groovy.lang.Closure)
Any insights on what I may be doing wrong? I just followed the steps that one would normally follow. I followed same steps to get the DeviceTamperAlarm.groovy added to my apps.
Thank you everyone, I bought 2 2 packs at Home Depot about a year ago on clearance and they have been sitting in my closet until today.
I am new to the device handler but you guys make it easy.
Thanks again
Bill
@mitchp and @twack
Mitch & Todd, was there an update to your old discussion about battery reporting on Quirky Trippers using Mitchās DTH? Iām trying to expose battery to ActionTles but itās not being reported. IDE shows Current States of only Contact and Tamper. Thanks so much for any help!
I am curious about battery status also. It shows % battery but never a number.
So a while ago I found that @mitchpās version only mapped volts up to 2.8 - when a battery was new and had voltage of 2.9 or above it didnāt have a percentage mapped to it - hence youād get _ _.
I made changes in the battery mapping to my own version of @mitchp 's excellent Quirky Tripper DTH to add in voltage range of 2.9 to 3.4 . I also tweaked the %values based on own experience and rough testing w/ multimeter.
The raw value is returned as voltage x10 (so 2.9 volts comes back as 29). Percentage results based on my own experience (once itās down to 2.4 volts itās almost gone - so I mapped it to 25% - by 2.1 volts itās losing connection - so I mapped it to 0 - that said my batteries are lasting months and months - even the one on the back door.
Hereās my tweaked version of that section of the DTH.
//Converts the battery level response into a percentage to display in ST
//and creates appropriate message for given level
//AlecM - 8-31 Added mapping values for 34 -29 to map below -since they were valid values - 3 or 2.9 volts were returning null
private getBatteryResult(volts) {
def batteryMap = [34:100, 33:100, 32:100, 31:100, 30:100, 29:95, 28:90, 27:80, 26:75, 25:50, 24:25, 23:20,
22:10, 21:0]
def minVolts = 21
//AlecM 10-2 changed maxvolts to 34 to see what really getting w/ new battery
def maxVolts = 34
def linkText = getLinkText(device)
def result = [name: ābatteryā]
if (volts < minVolts) volts = minVolts
else if (volts > maxVolts) volts = maxVolts
result.value = batteryMap[volts]
result.descriptionText = ā${linkText} battery was ${result.value}%ā
log.debug(ā${linkText} reports battery voltage at ${result.value}%ā) //added logging for voltage level to help determine actual min voltage from users
return result
Or you can get the whole thing at https://github.com/alecm/SmartThingsADM/blob/master/quirky-wink-tripper.src/quirky-wink-tripper-ADM.groovy
(no - Iām not set up with proper repo update or anything - never quite got around to it).
Hope this is useful! I love my Quirky trippers -
And battery level (in percentage) shows up just fine in my ActionTiles (just set up a new panel).
Alec
This is fantastic. I have lots of trippers as I am a wink convert. Currently just playing around with some of the items I was not sure about on this platform and still learning.
I edited the device handler and added all of the code from your link. It now shows type as tripper - AlecM. Is there anything else I need to do?
