Hello. I’m new to Home Automation. Thank you for this lovely forum and sharing your knowledge.
I have a Qubino Flush 1 Relay that I would like to install behind a light switch (Live, Load, and Neutral wires are present)
Is the Qubino only for outlets? I’ve watched a video about wiring a switch, but I don’t see a load wire from the wall in the video.
If anyone has a photo or a video of successfully wiring a qubino relay behind a switch, I would really appreciate it. I’m including a photo of my original switch plus what I did that didn’t work.
This device is designed to control one light at a time, so in case of a setup like this you should wire neutral to N contact, live to L contact on the device and also wire the switch to connect/break the live line that goes into the I1 contact.
So, when you’ll activate the physical switch the live current will go into I1 and when it’s not active no live current will go into I1.
The device also supports some other wiring via specific configuration settings, but for that you’ll have to look into the device’s manual.
