I need some help. Very new to Groovy. Took the newest Arrival Sensor Device Handler and am trying to add a simple toggle to turn it off or on. Without even affecting the presence status I cannot get the simple on/off toggle to function. I have the tile showing up and it is clickable but clicking momentarily sets the value from On to Off and then it reverts back to On again. Please help with my code to be able to have the On/Off status at least stay until the tile is tapped again. Thanks.
import groovy.json.JsonOutput
* Copyright 2017 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Better Arrival Sensor", namespace: "smartthings", author: "jasonfishbein") {
capability "Tone"
capability "Actuator"
capability "Presence Sensor"
capability "Sensor"
capability "Battery"
capability "Configuration"
capability "Health Check"
fingerprint inClusters: "0000,0001,0003,000F,0020", outClusters: "0003,0019",
manufacturer: "SmartThings", model: "tagv4", deviceJoinName: "Arrival Sensor"
preferences {
section {
image(name: 'educationalcontent', multiple: true, images: [
"http://cdn.device-gse.smartthings.com/Arrival/Arrival1.png",
"http://cdn.device-gse.smartthings.com/Arrival/Arrival2.png"
section {
input "checkInterval", "enum", title: "Presence timeout (minutes)", description: "Tap to set",
defaultValue:"2", options: ["2", "3", "5"], displayDuringSetup: false
tiles {
standardTile("presence", "device.presence", width: 2, height: 2, canChangeBackground: true) {
state "present", labelIcon:"st.presence.tile.present", backgroundColor:"#00a0dc"
state "not present", labelIcon:"st.presence.tile.not-present", backgroundColor:"#ffffff"
standardTile("beep", "device.beep", decoration: "flat") {
state "beep", label:'', action:"tone.beep", icon:"st.secondary.beep", backgroundColor:"#ffffff"
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false) {
state "battery", label:'${currentValue}% battery', unit:""
standardTile("guestKey", "device.guestKey") {
state "on", label:'ON', action:"disable", icon: "st.switches.light.on", backgroundColor:"#ffffff"
state "off", label:'OFF', action:"enable", icon: "st.switches.light.off", backgroundColor:"#cccccc"
main "presence"
details(["presence", "beep", "battery","guestKey"])
def disable() {
log.debug "disable"
sendEvent(name: "guestKey", value: "off")
return [disable]
//sendEvent(name: "presence", value: "not present")
def enable() {
log.debug "enable"
sendEvent(name: "guestKey", value: "on")
return [enable]
def updated() {
startTimer()
def installed() {
// Arrival sensors only goes OFFLINE when Hub is off
sendEvent(name: "DeviceWatch-Enroll", value: JsonOutput.toJson([protocol: "zigbee", scheme:"untracked"]), displayed: false)
def configure() {
def cmds = zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0020) + zigbee.batteryConfig(20, 20, 0x01)
log.debug "configure -- cmds: ${cmds}"
return cmds
def beep() {
log.debug "Sending Identify command to beep the sensor for 5 seconds"
return zigbee.command(0x0003, 0x00, "0500")
state.lastCheckin = now()
handlePresenceEvent(true)
if (description?.startsWith('read attr -')) {
handleReportAttributeMessage(description)
return []
private handleReportAttributeMessage(String description) {
def descMap = zigbee.parseDescriptionAsMap(description)
if (descMap.clusterInt == 0x0001 && descMap.attrInt == 0x0020) {
handleBatteryEvent(Integer.parseInt(descMap.value, 16))
* Create battery event from reported battery voltage.
* @param volts Battery voltage in .1V increments
private handleBatteryEvent(volts) {
def descriptionText
if (volts == 0 || volts == 255) {
log.debug "Ignoring invalid value for voltage (${volts/10}V)"
else {
def batteryMap = [28:100, 27:100, 26:100, 25:90, 24:90, 23:70,
22:70, 21:50, 20:50, 19:30, 18:30, 17:15, 16:1, 15:0]
def minVolts = 15
def maxVolts = 28
if (volts < minVolts)
volts = minVolts
else if (volts > maxVolts)
volts = maxVolts
def value = batteryMap[volts]
if (value != null) {
def linkText = getLinkText(device)
descriptionText = '{{ linkText }} battery was {{ value }}'
def eventMap = [
value: value,
descriptionText: descriptionText,
translatable: true
log.debug "Creating battery event for voltage=${volts/10}V: ${linkText} ${eventMap.name} is ${eventMap.value}%"
sendEvent(eventMap)
private handlePresenceEvent(present) {
def wasPresent = device.currentState("presence")?.value == "present"
if (!wasPresent && present) {
log.debug "Sensor is present"
startTimer()
} else if (!present) {
log.debug "Sensor is not present"
stopTimer()
def descriptionText
if ( present )
descriptionText = "{{ linkText }} has arrived"
else
descriptionText = "{{ linkText }} has left"
def eventMap = [
value: present ? "present" : "not present",
linkText: linkText,
translatable: true
log.debug "Creating presence event: ${device.displayName} ${eventMap.name} is ${eventMap.value}"
sendEvent(eventMap)
private startTimer() {
log.debug "Scheduling periodic timer"
runEvery1Minute("checkPresenceCallback")
private stopTimer() {
log.debug "Stopping periodic timer"
unschedule()
def checkPresenceCallback() {
def timeSinceLastCheckin = (now() - state.lastCheckin) / 1000
def theCheckInterval = (checkInterval ? checkInterval as int : 2) * 60
log.debug "Sensor checked in ${timeSinceLastCheckin} seconds ago"
if (timeSinceLastCheckin >= theCheckInterval) {
handlePresenceEvent(false)
