does anyone have a suitable driver for the Ikea redret button /dimmer , ive tried searching and using different drivers but canβt get anything to work, I just want to use it as a simple button to trigger routines,
Hello - hoping that someone can create an edge driver for the Iris V3 IL02_1 Zigbee Keypad.
Hereβs a screenshot of the device profile as reported by βZigbee Thing Mcβ driver from @Mariano_Colmenarejo
A recently acquired zigbee button from AliExpress pairs as a zigbee switch and thus doesnβt work as a button.
Hereβs what displays when the driver is swapped to @Mariano_Colmenarejo thing driver.
Can this be added to Marioβs or anyone elseβs drivers?
Bedside Button
Home -Bedroom
Device Information:
Manufacturer:
TZ3000_qgwcxxws
Model:TS0041
FingerPrinted_EndPoint.ld: 0x01
App Version: Unknown
ZCL Version: Unknown
Network ID: OxE715
Zigbee EUI: A4C13815741FFC3B
Device ID: cc1403e4-585e-4f38-
b38d-062790222869
Server Cluster:
Ep: 0x02=(0006,0001,0006 )
Ep: 0x01=/ 0001,0006,E000,0000
Ep: 0x04=( 0006,0001,0006)
Ep: 0x03=<0006,0001,0006 )
Controls
Routines
History
Client Clusters:
Ep: 0x01=<0019,000A)
Aha, looks like @erickv hasnβt logged on here for 71 days, can anyone else offer any suggestions, would any of your drivers @Mariano_Colmenarejo be a fit for this zigbee button and if so could you add it?
Hello all. I am requesting if there is an edge driver for IRIS Duraflame Zigbee Heater. I had it working with custom drivers based on a zigbee DTH, but it stopped working after recent changes. Now the device is being recognized as a βThingβ with a Zigbee Switch driver assigned to it. But the switch function also does not work (heater does not turn on/off when using the button). My search in this forum did not turn up any existing drivers (other than some old threads). Thanks.
**Hi would you be able to add a driver or fingerprint for CentralLite Thermostat 3156105. itβs an older version than the Pearl touch version that was added to an edge driver. See this post. See device info i found. If more info is needed, do let me know. Thank you kind
Hi @Mariano_Colmenarejo. Thanks for your efforts. Iβm probably missing something, The driver, updated version is installed on the hub, but cannot add it to the Thermostat. Restarted / removed / reinstalled everything, Your driver is update. See screenshots.
I am using some of your edge drivers from your channel. Itβs a big help for me to establiah the smart home.
I have bought a Tuya zigbee smoke detector and tried to connenct to ST station. However, I cannot find thd driver fod that. Would you please add this zigbee to Zigbee smoke detection driver?
Is it possible to include a driver for Ikea Symfonisk Gen. 2?
Samsung SmartThings beta edge driver package contain drivers for 2 button and 5 button from Ikea, but not for this 7 button.
Added to this driver version.
IMPORTANT: Do not perform a driver change from zigbee Thing Mc driver. You need to uninstall device and pair with this new driver version installed in your Hub
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Smoke/CO Detector Mc
Version 2023-11-06T21:27:49.680680495
- id: "_TYZB01_up3pngle/TS0205"
deviceLabel: Nedis Smoke Detector
manufacturer: _TYZB01_up3pngle
model: TS0205
deviceProfileName: smoke-battery
This device is supported by Zigbee Motion Sensor Mc since two years ago. I have one sensor installed.
Install driver in your hub from my shared channel
