The problems you’re running into because it’s a scene controller, not just a button controller. And it’s using Z wave specific scene controls.
Because SmartThings is a multiprotocol platform it doesn’t want its customers to have to know whether a device is zigbee or Z wave. So it just doesn’t use the built-in Z wave scene controller functionality.
I Think the best thing at this point would be for you to read the two recent threads on light controls available for the UK.
After that people can help you work on a device type for this specific switch if you want. There is a UK community member working on a device type for one of the Z wave.me similar switches, but he doesn’t have it finished yet. Following his process would probably help you a lot, though.
So, I would encourage you to take the following three steps. These are all clickable links that will take you to discussion threads.
One) read the FAQ on lighting controls currently available to UK customers.
Two) read the couple of posts that are the technical discussion regarding multibutton zwave switches that use scene control
Three) glance over the work that’s being done on the Z wave.me switch type
Trying to go the secondary controller route is unlikely to give you the results you want, again because that’s utilizing zwave–specific functions and the SmartThings architecture just doesn’t tend to support those kinds of solutions.
If you started with the popp switch as the primary, and moved things over, you might end up with a situation where the physical switch buttons would control the lights you wanted, but their status would never get updated to smartthings which causes a bunch of other issues. I’m not saying it’s impossible to work around, I just think you’ll get better results with the approaches outlined in the links above.
Good luck and welcome! The community has done a great job of developing device types for many different devices which have to work a little differently in the SmartThings environment. But that environment is what lets us mix Zigbee and zwave devices in the same “scene”, so most people are very happy once they get it set up. Or if they only use devices that already have existing device types.
