Having an issue I can’t seem to figure out.
I have piston set to set the levels of 3 lights when a contact opens. First it well set the level to 100% and then it’s supposed to wait 30 minutes then set the to 50% and then wait another 15 minutes and set the level to 10%.
When the contact opens it will set the level to 100% and schedule the timer but when the timer runs down it doesn’t do the set level 50%?
What am I missing? I had this set-up on another set-up but had to start fresh again and now it’s not working correctly…!
Here is the most recent log:
Logs
8/7/2018, 1:17:48 PM +57ms
+1ms ╔Received event [Home].time = 1533673069743 with a delay of -1687ms
+159ms ║RunTime Analysis CS > 38ms > PS > 60ms > PE > 61ms > CE
+161ms ║Runtime (38244 bytes) successfully initialized in 60ms (v0.3.106.20180731) (159ms)
+162ms ║╔Execution stage started
+163ms ║╚Execution stage complete. (1ms)
+164ms ╚Event processed successfully (164ms)
8/7/2018, 12:47:53 PM +210ms
+1ms ╔Received event [Front Door].contact = closed with a delay of 361ms
+140ms ║RunTime Analysis CS > 24ms > PS > 68ms > PE > 48ms > CE
+142ms ║Runtime (38237 bytes) successfully initialized in 68ms (v0.3.106.20180731) (140ms)
+143ms ║╔Execution stage started
+152ms ║║Comparison (string) :fcbe69a89a7885db0af0df65673d7500: is_any_of (string) :4cfad1470a3a40f39be1cdd774879ec1:,:fcbe69a89a7885db0af0df65673d7500: = true (2ms)
+153ms ║║Condition #9 evaluated true (5ms)
+154ms ║║Condition group #1 evaluated true (state did not change) (6ms)
+158ms ║║Comparison (enum) closed changes_to (string) open = false (0ms)
+159ms ║║Cancelling condition #8’s schedules…
+160ms ║║Condition #8 evaluated false (4ms)
+160ms ║║Cancelling condition #1’s schedules…
+161ms ║║Condition group #1 evaluated false (state changed) (7ms)
+163ms ║╚Execution stage complete. (21ms)
+164ms ╚Event processed successfully (165ms)
