To test from scratch I copied and pasted your entire code sample from github and commented out the 1 line as below.
In the Device Settings these are the details:
Device Network Id c0a80179:1f40
Hub Home Hub
Camera IP Address: 192.168.1.121
Camera Port: 8000
Camera Path to Image: /GPIO/17/value/1
Does Camera require User Auth?: false
Does Camera use a Post or Get, normally Get?: POST
Camera User:
Camera Password:
CODE:
metadata {
definition (name: "TestPost2", namespace: "ps", author: "patrick@patrickstuart.com") {
capability "Image Capture"
capability "Sensor"
capability "Actuator"
preferences {
input("CameraIP", "string", title:"Camera IP Address", description: "Please enter your camera's IP Address", required: true, displayDuringSetup: true)
input("CameraPort", "string", title:"Camera Port", description: "Please enter your camera's Port", defaultValue: 80 , required: true, displayDuringSetup: true)
input("CameraPath", "string", title:"Camera Path to Image", description: "Please enter the path to the image", defaultValue: "/SnapshotJPEG?Resolution=640x480&Quality=Clarity", required: true, displayDuringSetup: true)
input("CameraAuth", "bool", title:"Does Camera require User Auth?", description: "Please choose if the camera requires authentication (only basic is supported)", defaultValue: true, displayDuringSetup: true)
input("CameraPostGet", "string", title:"Does Camera use a Post or Get, normally Get?", description: "Please choose if the camera uses a POST or a GET command to retreive the image", defaultValue: "GET", displayDuringSetup: true)
input("CameraUser", "string", title:"Camera User", description: "Please enter your camera's username", required: false, displayDuringSetup: true)
input("CameraPassword", "string", title:"Camera Password", description: "Please enter your camera's password", required: false, displayDuringSetup: true)
simulator {
tiles {
standardTile("camera", "device.image", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: true) {
state "default", label: "", action: "", icon: "st.camera.dropcam-centered", backgroundColor: "#FFFFFF"
carouselTile("cameraDetails", "device.image", width: 3, height: 2) { }
standardTile("take", "device.image", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false) {
state "take", label: "Take", action: "Image Capture.take", icon: "st.camera.camera", backgroundColor: "#FFFFFF"
state "taking", label:'Taking', action: "", icon: "st.camera.take-photo", backgroundColor: "#53a7c0"
state "image", label: "Take", action: "Image Capture.take", icon: "st.camera.camera", backgroundColor: "#FFFFFF"
main "camera"
details(["cameraDetails", "take", "error"])
log.debug "Parsing '${description}'"
def map = stringToMap(description)
def result = []
if (map.bucket && map.key) { //got a s3 pointer
putImageInS3(map)
else if (map.headers && map.body) { //got device info response
def headerString = new String(map.headers.decodeBase64())
if (headerString.contains("404 Not Found")) {
state.snapshot = "/snapshot.cgi"
if (map.body) {
def bodyString = new String(map.body.decodeBase64())
def body = new XmlSlurper().parseText(bodyString)
def productName = body?.productName?.text()
if (productName) {
log.trace "Product Name: $productName"
state.snapshot = ""
result
def putImageInS3(map) {
def s3ObjectContent
try {
def imageBytes = getS3Object(map.bucket, map.key + ".jpg")
if(imageBytes)
s3ObjectContent = imageBytes.getObjectContent()
def bytes = new ByteArrayInputStream(s3ObjectContent.bytes)
storeImage(getPictureName(), bytes)
catch(Exception e) {
log.error e
finally {
if (s3ObjectContent) { s3ObjectContent.close() }
// handle commands
def take() {
def userpassascii = "${CameraUser}:${CameraPassword}"
def userpass = "Basic " + userpassascii.encodeAsBase64().toString()
def host = CameraIP
def hosthex = convertIPtoHex(host)
def porthex = convertPortToHex(CameraPort)
device.deviceNetworkId = "$hosthex:$porthex"
log.debug "The device id configured is: $device.deviceNetworkId"
def path = CameraPath
log.debug "path is: $path"
log.debug "Requires Auth: $CameraAuth"
log.debug "Uses which method: $CameraPostGet"
def headers = [:]
headers.put("HOST", "$host:$CameraPort")
if (CameraAuth == "true") {
headers.put("Authorization", userpass)
log.debug "The Header is $headers"
def method = "GET"
try {
if (CameraPostGet.toUpperCase() == "POST") {
method = "POST"
catch (Exception e) { // HACK to get around default values not setting in devices
settings.CameraPostGet = "GET"
log.debug e
log.debug "You must not of set the perference for the CameraPOSTGET option"
log.debug "The method is $method"
try {
def hubAction = new physicalgraph.device.HubAction(
method: method,
path: path,
headers: headers
//hubAction.options = [outputMsgToS3:true]
log.debug hubAction
hubAction
log.debug "Hit Exception $e on $hubAction"
private getPictureName() {
def pictureUuid = java.util.UUID.randomUUID().toString().replaceAll('-', '')
return device.deviceNetworkId + "_$pictureUuid" + ".jpg"
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize( '.' ).collect { String.format( '%02x', it.toInteger() ) }.join()
log.debug "IP address entered is $ipAddress and the converted hex code is $hex"
return hex
private String convertPortToHex(port) {
String hexport = port.toString().format( '%04x', port.toInteger() )
log.debug hexport
return hexport
private Integer convertHexToInt(hex) {
Integer.parseInt(hex,16)
private String convertHexToIP(hex) {
log.debug("Convert hex to ip: $hex")
[convertHexToInt(hex[0..1]),convertHexToInt(hex[2..3]),convertHexToInt(hex[4..5]),convertHexToInt(hex[6..7])].join(".")
private getHostAddress() {
def parts = device.deviceNetworkId.split(":")
log.debug device.deviceNetworkId
def ip = convertHexToIP(parts[0])
def port = convertHexToInt(parts[1])
return ip + ":" + port
