Synthesis
(The Viking AKA "Holy Crap You're a Giant!")
103
I found a really great WS2812b library with 53 effects for running NeoPixel strings, but I only have an ESP8266 board so have no way to get your setup running on it, especially without any actual development knowledge.
I read earlier in this thread where someone else was working with the ESP8266 unit as well… Is anyone willing to “port” this over to the ESP8266 units, possibly with the WS2812FX Library?
I’d really like to control the Christmas lights I’m installing on the front of the house with SmartThings, rather than having to hit the ESP unit directly via a browser.
Do you have the full functioning code for the esp that I could look at, is that the ws2812fx library?
Synthesis
105
The ws2812fx library has an ESP8266 “Example” listed underneath the Examples folder.
It includes the necessary html and js files as part of the example, and works directly “out of the box” when flashed to an ESP8266 device with the necessary pin, pixel count, and pixel format edits. I flashed it onto an Adafruit Huzzah Feather with only those three changes and have been playing with it ever since.
nowadays the dc12v individual pixel led strip is available now,
I have got a type of gs8208,can share the code of ws2811,but it is dc12v individual pixel,
it works great.
Okay, I bought the $19 board because I assumed this code would work. Now it won’t compile. Do I include the Particle IDE’s own neopixel library or the one you included? You can’t name a .h or .cpp file with a space in it, so I don’t understand how yours ever compiled in the first place. When I uploaded using the default Particle neopixel library I get no control from SmartThings. So, a little assistance would be greatly appreciated.
Okay…so I am still unable to control the device. I have gotten my access token from Particle Build. Do I have to create a Oauth client or just my access token?
In the DTH or in the device settings? Or both?
Also, I’ve noticed that the brightness slider never goes above 0. As soon as I back out it drops back to zero again. You are actually using this code?
In the smarttings app if you go under your device there is a settings gear. That is where you place the access token and and device id. Yes this is working the slider should remain after you have the device working.
Tried rebuilding the program from scratch and was able to use your neopixel.h and neopixel.cpp. Still nothing in my control from SmartThings.
When I go into livelogging, I don’t actually see any commands going out from the device to the Particle API. I ask again, does anyone have this actually working?
9ae417a3-627b-406d-afcb-de9586e3755b 6:39:57 PM: debug switch is on
9ae417a3-627b-406d-afcb-de9586e3755b 6:39:55 PM: debug switch is off
9ae417a3-627b-406d-afcb-de9586e3755b 6:39:51 PM: debug switch is on
9ae417a3-627b-406d-afcb-de9586e3755b 6:39:50 PM: debug switch is off
9ae417a3-627b-406d-afcb-de9586e3755b 6:39:47 PM: debug switch is on
That’s all I see when I turn the switch on and off.
Okay…cause from what I’m seeing in LiveLogging it’s not even trying to send any of my setting out to Particle. So, i don’t know what that change is going to do. I will ask this again, you have personally used the DTH to program a board from scratch and it worked? Because I don’t see how it does. There are no calls going out to the board. Ever.
And I just checked…the oldest version is 4.1. So, no go there either. Try again.
