Override Smart Lighting Automation with scenes
I have my lights set to turn on at 15 percent when motion is sensed at night. This keeps you from getting blinded bit give you enough light to see.
Sometime I want to be able to see at night. I would like to have a scene that will override and pause the smart Lighting app program for a hour, the return to regular programing. I could do this with webcore and routines but I can’t get the old app and my routines. I also had some issue with webcore not working properly so I switched to smart lighting app and find it much easier.
I would also like to be able to tell alexa to turn on all the lights as an over ride. Does anyone know how I can go about doing this?
Please help or point me in a direction!
Create a virtual switch - call it something like override
Add criteria to your Smartlighting automation such thay it will not run When this switch is on
Tell Alexa to turn on the override
I do something similar. I have a virtual device for each room where I can tell Alexa to turn off the automations for that room, she turns off the virtual switch which pauses the corresponding piston in Webcore.
Then I manipulate the lights however I want and they’ll stay that way. When I’m done, I tell Alexa to turn on automations for that room and everything goes back to normal the next time motion triggers the resumed piston.
How do I create a virtual switch?
New app homescreen>tap hamburger in upper left>tap Smart Apps>tap waterfall in upper right>tap smartthings labs>tap virtual switch (2nd from bottom)>Follow the prompts.
There’s also a more complex way of doing it in the IDE but since the IDE access will eventually go away and this solution works, I recommend it.
