Thanks for the reply.
Tried erocm123 virtual DH and it now works with your physical DH!
Now only to get the virtual DH to work as a momentary switch.
I am only starting to get into ST and haven’t got any programming/scripting experience but I will have a go.
Let me know if you can get them working as momentary switches.
Alexhp11
(Alex)
February 20, 2018, 2:20am
22
Did anyone get this working with a momentary virtual DH ? im trying to do the same thing …
Alexhp11
(Alex)
March 12, 2018, 12:04am
23
so i guess its over ? no one can help ?
brumster
(Paul)
March 12, 2018, 11:32am
24
I never did get it working. I just set up a web core rule to turn the thing where it turned on.
If you want a momentary then I’d use the fibaro relay, it has a parameter setting so the momentary is handled but he device, which is of course bulletproof.
Alexhp11
(Alex)
March 13, 2018, 2:22pm
25
thanks for the input… of course i have bigger problems now as the whole system has been on and off for the past day or so…
may have to look at the fibaro… its a dual relay though not 3 relay correct ? ( open and close but no stop i guess)
that’s why i chose the orvibo as it had all 3 inputs for the curtain covered ( open . close, and stop)
Avron
November 27, 2019, 3:07am
26
Just wanted to tack this to this thread instead of start a new one.
I have used this device handler successfully to managed a Solaredge Smart Energy Relay to allow that to be used outside of the Solaredge ecosystem.
