On/Off Switch Vision ZL7431US
I am planning to use this relay for garage door opener.
I am not that much familiar with electrical stuff. I am planning following wiring diagram (based on the diagram posted by @NomadTech):
Relay white (Neutral) -> Powerline white (Neutral)
Relay black (Live) -> Powerline black (Live)
Relay Red (Common) -> one end of current garage door switch
Relay Blue (NO) -> other end of current garage door switch
Relay Yellow (NC) -> remains open/unconnected
Relay Green (Trigger) -> remains open/unconnected
Will it work? Do I need to add anything else in terms of wiring?
In terms of DH, I believe, I need the behavior of a momentary switch (or logic to integrate with garage door tilt sensor).
TIA
Yes. Any dry contact parallel to current button opener will work.
Absolutely. Set it like 2-4 seconds to account for delays in cloud communications.
So if I’m trying to use this device in my basement with 5 lights and two switches, with power to the lights first like your option 3. Do I need to identify the first light that’s getting power from the breaker box in order to install this there?
