I guess I misunderstood. I thought you wrote in your post that it was broke by a ST hub update or something like that.
The device wasn’t working at all - when I pressed a button, its LED light would flash rapidly for about 3 seconds and then all the LEDs would flash. Power cycle to the switch didn’ thelp.
So I thought I would just do a factor reset on it it. That worked. But I can’t figure out how to get the device added back into ST. When I follow the PDF instructions for it, it flashes slowly for about 5 seconds and then goes back to all lights on solid. I try telling ST to scan for new devices during this period but it doesn’t find anything. I don’t know how to tell it to look specifically for the Enverwave device as it doesn’t show up on the list.
You need to load and publish the custom device handler and smart app from mattjfrank / ZWN-SC7 Enerwave 7 Button Scene Controller, then st will be allowed to add it as a device and program the buttons, ND to do this from st ide…
which has a note " Last Update: 2021-01-26 update by Tim Grimley to work in new Smartthings app"
So I create a new DTM “from code” and published it.
I then followed the manual add steps from Enerwave, press bottom buttom for 3 seconds, press left hand column of lights. And while that slow blinks I do “scan nearby” on ST app, but no device found.
Can you please explain the steps to try and get ST to recognize it? Thanks!
Hi guys - After weeks of trying to figure out how to get the ZWN-SC7 working again, I had no choice but to buy a different controller. I picked up the Zooz Scene Controller which I like (in some ways even better!). But I’m having an issue in it where webCore only picks up the main button. The other 4 buttons, controlled via a different DTH, don’t show up.
