[OBSOLETE] SmartBulb Power Outage handler
Updated the code to also poll the monitored light bulbs. This should now pick up bulbs that were turned on by the physical switch and smartthings didn’t pick up the change (mainly for CREE bulbs). This should avoid turning those lights off after a power outage.
 *  Smarter Bulbs
 *  Copyright 2016 Nick Sweet.
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 * Metadata *
definition(
	namespace: "nsweet68",
	author: "nick@sweet-stuff.cc",
	description: "Save the state of a bunch of bulbs and reset when 'Canary' bulb turns on",
	category: "My Apps",
	iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/App-LightUpMyWorld.png",
	iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/App-LightUpMyWorld@2x.png"
preferences {
    section("Canary Bulb") {
        input "canary", "capability.switch", title: "Who sings?"
    section("Zigbee bulbs to monitor") {
        input "slaves","capability.switch", multiple: true
def installed() {
    log.debug "Installed with settings: ${settings}"
    initialize()
def updated() {
    log.debug "Updated with settings: ${settings}"
    unsubscribe()
    initialize()
def initialize() {
    subscribe(slaves, "switch", saveStates)
    subscribe(canary,"switch.on", checkRestore)
    pollCanary()
    saveStates()
	runEvery5Minutes(checkRestore)
def saveStates(evt) {
	log.debug "Checking States"
    if ("off" == canary.currentSwitch ) {
    	def lightsOff = [:]
    	slaves?.each {
			if (it.currentSwitch == "off"){
        	log.debug "${it.displayName} value ${it.currentSwitch}"
        	lightsOff[it.id]="off"
   	state.lOff = lightsOff
def checkRestore(evt) {
    log.debug "Checking Restore"
    pollCanary()
    log.debug "Canary is ${canary.currentSwitch}"
    if ("on" == canary.currentSwitch) {
    	log.debug "Turning stuff off"
        restoreState()
        canary.off()
    pollSlaves()
    saveStates(evt)
private restoreState() {
  slaves?.each {
				if (state.lOff[it.id] == "off") {
                log.debug "turning $it.label off"
				it.off()
private pollCanary() {
    def hasPoll = canary.hasCommand("poll")
    if (hasPoll) {
    	canary.poll()
        log.debug "Poll canary"
    else
    	canary.refresh()
        log.debug "Refresh canary"
private pollSlaves() {
slaves.each {slave ->
def hasPoll = slave.hasCommand("poll")
    if (hasPoll) {
    	slave.poll()
        log.debug "Poll ${slave.displayName}"
    else
    	slave.refresh()
        log.debug "Refresh ${slave.displayName}"
