[OBSOLETE] Russound Multi-Zone Controller Integration
It’s been a while since I did a fresh install so I don’t remember if the node version matters. I’m surprised you’re still getting a 5.0.0 error if you deleted the version from your package.json. Try running:
npm install serialport
from the command line. Then, from the folder where your package.json is saved, run:
npm install
Then try to start the server.
“port”: 8082,
“authCode”: “secret”,
“rnet”: {
“c-series”: true,
“serialPort”: “/dev/ttyUSB0”,
“sources”: [
“Tuner”,
“Music Server”,
“Great Box”,
“Master Box”,
“Porch Box”,
“Echo Dot”
“controllerConfig”: {
“type”: “discover”,
“controllers”: [
“controller”: 0,
“zones”: [
“zone”: 0,
“name”: “Great Room”
“zone”: 1,
“name”: “Kitchen”
“zone”: 2,
“name”: “Porch”
“zone”: 3,
“name”: “Master Bath”
“zone”: 4,
“name”: “Workshop”
“zone”: 5,
“name”: “Master Shower”
“notify”: {
“address”: “192.168.0.12”,
“port”: “39500”
Me too! And it was quite difficult then. I had ZERO knowledge of Raspberry Pi at that time. Now I cannot remember how I did it. Here we go…
pi@raspberrypi:~/Downloads/smartthings-nodeproxy $ npm install serialport
npm WARN deprecated mkdirp@0.5.4: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
serialport@8.0.7 postinstall /home/pi/Downloads/smartthings-nodeproxy/node_modules/serialport
node thank-you.js
Thank you for using serialport!
If you rely on this package, please consider supporting our open collective:
Contribute - Open Collective
smartthings-nodeproxy@1.0.0 /home/pi/Downloads/smartthings-nodeproxy
└── (empty)
npm ERR! code 1
Have you run update on your Pi?
sudo apt update
sudo apt full-upgrade
pi@raspberrypi:~/Downloads/smartthings-nodeproxy sudo apt update Hit:1 https://deb.nodesource.com/node_6.x buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 http://archive.raspberrypi.org/debian buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. pi@raspberrypi:~/Downloads/smartthings-nodeproxy sudo apt full-upgrade
Reading package lists… Done
Reading state information… Done
Calculating upgrade… Done
The following packages were automatically installed and are no longer required:
libc-ares2 libnode64 libuv1 nodejs-doc
Use ‘sudo apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Since the warning calls out mkdirp being an old version, you probably also need to run:
npm update
to get node.js to update all of its installed packages. Then try the lines I posted again to install serialport.
Ok. And you’re sure that USB0 is the right port?
Affirmative.
Still getting that same error.
Try:
npm install mkdirp
and/or:
npm update mkdirp
I had hopes…but alas…
pi@raspberrypi:~/Downloads/smartthings-nodeproxy $ node server.js
[2020-03-29T16:43:27.522Z] [stnp] SmartThings Node Proxy listening at http://:::8082
/home/pi/Downloads/smartthings-nodeproxy/node_modules/@serialport/stream/lib/index.js:103
const settings = { …defaultSettings, …options }
SyntaxError: Unexpected token …
at createScript (vm.js:56:10)
at Object.runInThisContext (vm.js:97:10)
at Module._compile (module.js:549:28)
at Object.Module._extensions…js (module.js:586:10)
at Module.load (module.js:494:32)
at tryModuleLoad (module.js:453:12)
at Function.Module._load (module.js:445:3)
at Module.require (module.js:504:17)
at require (internal/module.js:20:19)
at Object. (/home/pi/Downloads/smartthings-nodeproxy/node_modules/serialport/lib/index.js:1:82)
Maybe it’s time to do a complete wipe of raspbian and install completely fresh?
For the fifth time in 24 hours? LOL
oh! ouch.
ok. What if I send you an image of my Raspbian and you install that image on your Rpi? Then just change the plugins to Russound?
Sounds good to me :+1:
ok. I’m running a Pi Zero W so i’m not entirely sure if that will work on yours.
I don’t think that it will. Thanks anyway.
OK, I think that I have a running version. Does anyone have an autoboot rc.local file they would be willing to share?
Here are my step by step instructions for setting up autoboot. It’s for a different plugin, but everything should be the same.
Was working well 2 hours ago. Unplugged the RPi. Ate dinner. Plugged it back in. Now it won’t do anything but turn the speaker on/off. Nothing else. It was throwing this error before and was working. Not working now. Any thoughts?
[2020-03-30T01:20:28.750Z] [stnp] SmartThings Node Proxy listening at http://:::8082
[2020-03-30T01:20:28.880Z] [stnp] Loaded plugin: rnet
(node:1226) UnhandledPromiseRejectionWarning: TypeError: SerialPort.list no longer takes a callback and only returns a promise
at Function.SerialPort.list (/home/pi/Downloads/smartthings-nodeproxy/node_modules/@serialport/stream/lib/index.js:651:11)
at getSerialPorts (/home/pi/Downloads/smartthings-nodeproxy/plugins/rnet.js:401:16)
at Rnet.init (/home/pi/Downloads/smartthings-nodeproxy/plugins/rnet.js:147:5)
at Object. (/home/pi/Downloads/smartthings-nodeproxy/plugins/rnet.js:131:6)
at Module._compile (module.js:653:30)
at Object.Module._extensions…js (module.js:664:10)
at Module.load (module.js:566:32)
at tryModuleLoad (module.js:506:12)
at Function.Module._load (module.js:498:3)
at Module.require (module.js:597:17)
(node:1226) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
(node:1226) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
[2020-03-30T01:20:28.892Z] [rnet] Connected to RNET: /dev/ttyUSB0
