Hi @ygerlovin, I have good news. I just installed my 4 gangs switch and it was recognized as a “Thing”, then I went to the ST IDE and changed the device type to TS0601 Relay and after that, just a small config to set the number of gangs as 4 in the ST app and everything works well.
Here’s the zbjoin just in case you want to check something else:
update: backlight doesn’t work on the 4 gang switch. I really don’t need this functionality but if its possible to add it for others that would be great.
Hi @iwry
Thanks for the update.
Did you have a chance to check whether the parent switch is able to control all channels?
It is really unexpected, but perhaps Moes added support for controlling all gangs with a single command to 4 gangs model.
What about backlight? Does it work correctly?
Sorry, I don’t have a single Moes wall switch. I created this driver for a friend who has Tuya compatible (not Moes) module. Then I found out that it is fairly easy to add support for Moes.
Hello @ygerlovin how are you doing? It’s been a while since I’ve been using your DH and it is working well so far. Do you think it is possible to make the devices run locally? You told me something about making the DH official or something like that. Right? If there’s anything I could help you with to make it work just let me know! Have a nice weekend!
Hi @iwry,
I’m fine, thank you. How are you?
It is great to know DH is working well.
I’m currently working on edge driver for Tuya switches. It is quite quite different, so things are going really slow.
However, if I make it work, it will run locally.
Have a great weekend!
Cheers,
Yakov
The device handler I referred in my last message specifically only works for the 1st gang.
There is a newer Device Handler in this thread that allows you to enter the number of gangs (Number of children) from the Smartthings App Device Settings, and apparently works for multiple gangs.
Haven’t tested the new handlers yet, so not sure which is the latest and best to use.
(I didn’t use the new device handler because I only wanted to only activate the 1st gang for the 2 gangs that I had.)
should be working with multiple gangs.
You need to install both child and parent handlers, perform pairing and configure the number of gangs in the parent device
Hi there, first and foremost thanks for those of you that devoted you time to make these devices work. I just got the MOES 4 Gang Scene switch, I am trying to use the handlers but I can’t even see my device in the list of devices. I see many of you get the device to show up as a thing. I don’t even get that, am I missing anything? Do you make an entry manually?
Thanks much, Martin
If the device is supported by DTH it should appear as a specific device, not as a thing.
Could you please describe the pairing process you’re performing?
Do you see any messages in hub event log during pairing?
Do you have a model number and/or a link to the product page of your switch?
Regards
Whoever is using my DTH with Moes switches, could you please confirm the child lock actually works?
I’m working on edge driver for Tuya switches and would like to know whether ‘Child lock’ capability should be included for those devices.
The ‘Child Lock’ when enabled prevents using only a physical switch (i.e. pressing a button on the switch panel should have no effect). The automations and control from the APP should be working.
@ygerlovin thanks again for your time and efforts. It looks like many people have tried it and gave up as the latest version does not seem to work well with ST. I followed the instructions in the post you provided and finally got it to pair and all but it does not respond to the actions. Too bad as I really liked the device, it is somewhat elegant and could serve multiple purposes.
