If you’re using this app to program your codes it will show the name under the recently tab.
Seeing that you’re using RFID tags I assume you’re not using this app to program your cards but rather the RFID cards are programmed directly the lock and you’re using the following app:
We can continue the conversation in this topic to avoid confusion:
