Hi Troy,
I am not sure what process you have followed so far, but can see you are trying to install the forever service.
Have you used @adamclark_dev video? The instructions are a step by step, straight forward guide to installing this on your Pi. The forever service is covered in the last couple of minutes.
But before that, I would test if the LightwaveRF node.js is configured correctly, you can manually run it by typing “sudo node server.js” and pressing enter in the directory where your server.js file is (along with lwrf.js, router.js, helpers.js, handlers.js, etc.). You should receive a response saying “Server running”.
Once you have done that, in the same directory, type “sudo npm -g forever” and enter. The cursor will spin for a while then loads of text will appear below. Once you are back to the command prompt (pi@raspberrypi) continue below.
Now you will need to install the service for forever, type “forever-service install lwrf --script server.js” and press enter. It will do its thing quite quickly and should display some sample commands to control the service.
Commands to interact with service lwrf
Start - "sudo service lwrf start"
Stop - "sudo service lwrf stop"
Status - "sudo service lwrf status"
Restart - “sudo service lwrf restart”
You will now need to type “sudo service lwrf start” and enter, which will result in your lwrf service now running continuously. If there is an issue, or an outage, the service will automatically restart without your intervention.
Once you this side of it is done, you can now set your lights/sockets up in SmartThings in this video here..
Hopefully this helps. Good luck.
Chris.
