Hi @adamclark_dev
So I started checking out the logs, and run some on / off commands, all pretty instant, no missed commands and works as expected, Pretty much straight after it appears on the screen, lights were doing their thing. See log below.
pi@raspberrypi:~ $ tail -f /var/log/lwrf.log
On request received
Attempt 1 - Sending message: 004,!R3D2F1|
On request received
Attempt 1 - Sending message: 005,!R1D6F1|
Off request received
Attempt 1 - Sending message: 006,!R1D6F0|
On request received
Attempt 1 - Sending message: 007,!R1D6F1|
Attempt 1 - Sending message: 008,!R1D6F0|
On request received
Attempt 1 - Sending message: 009,!R3D1F1|
Attempt 1 - Sending message: 010,!R3D1F0|
Attempt 1 - Sending message: 011,!R3D2F0|
On request received
Attempt 1 - Sending message: 012,!R3D2F1|
On request received
Attempt 1 - Sending message: 013,!R3D2FdP25|
On request received
Attempt 1 - Sending message: 014,!R5D1F1|
On request received
Attempt 1 - Sending message: 015,!R5D1F1|
On request received
Attempt 1 - Sending message: 016,!R5D1F1|
On request received
Attempt 1 - Sending message: 017,!R5D1F1|
On request received
Attempt 1 - Sending message: 018,!R5D1F1|
Now here is where it gets interesting, and having very little coding experience, Iâm not sure what to make of it.
So I turned a few lights and made sure the bedside power was off and run âGood Nightâ and this is what happens in the log.
On request received
On request received
On request received
Attempt 1 - Sending message: 019,!R1D3F1|
/var/www/lwrf.js:181
if(this.queue.length > 10) this.queue.clear();
TypeError: this.queue.clear is not a function
at LightwaveRF.exec (/var/www/lwrf.js:181:43)
at LightwaveRF.turnDeviceOff (/var/www/lwrf.js:106:10)
at Object.exports.lwrfToggle (/var/www/helpers.js:28:8)
at null.<anonymous> (/var/www/server.js:12:10)
at process (/var/www/handler.js:8:19)
at Server.<anonymous> (/var/www/server.js:22:10)
at emitTwo (events.js:88:13)
at Server.emit (events.js:173:7)
at HTTPParser.parserOnIncoming [as onIncoming] (_http_server.js:529:12)
at HTTPParser.parserOnHeadersComplete (_http_common.js:89:23)
error: Forever detected script exited with code: 1
error: Script restart attempt #2
Server running
Receiver socket listening 0.0.0.0:9761
Any clues, is this something to do with the update or just coincidence / bad timing, as from what I see Iâm the only one that is having issues with Routines, as other who have mentioned it seem to be having more of an issue with lag or inconsistency etc.
Anyway hope this helps shed some light on what ever seems to be going on.
All the best, Craig
