Take a look at this modified DH by @ady624 in this thread. This DH is for SmartThings outlet but it also works with the Iris Smart Plug (3210-L). This one will show the accumulated power.
I donât really like the new changes to this device, why do I need to know how long it has been paired to my hub, also it seems to update the power usage every second. Is there a way I can I use the handler but only keep the on off ability. I donât need any of the other metrics.
I believe with these I switched the device handler to the stock ST onesâŚbecause I just need the local processing, and cost effective zigbee power outlets from the Loweâs discount wonderland (that appears to have closed)
Yes, the default âSmartPower Outletâ device handler works with the Iris plug. On the plus side the built in Device handler Watt meter work for real time output.
Well, I can see an improvement on my Nyce Hinge Door Sensors response time which is a zigbee sensor that was very far from my hub including a steel door in between. Should this just show as one device? Or two?
Interesting. Originally it came up as a zwave device which I force deleted when I was troubleshooting. I finally got the zigbee, outlet working but now I donât see the zwave device even after trying a device exclusion. Any ideas?
I just got this smart plug a couple of days ago, and this thread was invaluable in getting it set up. Initially the Zigbee radio paired without a problem, but I couldnât get the Z-Wave repeater to pair. I followed the directions in the initial post:
âŚthen I read more. It appeared that many people had slightly different problems, with slightly different answers, so I went on an experimentation journey based on what others had already tried and succeeded about 30 minutes later. Thank you to everyone for posting your experiences and suggestions! Iâm glad to be part of this community!
Hereâs what I ended up doing to get everything set up:
Created, saved and published the Device Handler from the link in the first post
Start âAdd Thingâ from the IOS ST app
Set up Zigbee smart plug
Tried, but failed to get plug into Z-Wave pairing mode.
Removed ZigBee device from ST
Did a Z-Wave exclusion via the IDE
Rebooted ST hub via the IDE
Reset the Iris Smart Plug (Hold button while plugging it in)
Add and configure the Iris Smart Plug thing
Rapidly press smart plug button 8 times (voila! Z-Wave pairing mode = 3-4 rapid blinks every ~10 seconds)
Add and configure Z-Wave Device
This is currently my only ZigBee device. At the time I had a single Z-Wave dimmer switch, a couple of Sonos devices, and node proxy (courtesy of @redloro) controlling a Russound stereo. Not a complex system overall, which may have contributed to the success.
tgauchat
358
Thanks for this note, the driver, and all the discussion and work here! I finally decided to install a couple of these, and, ⌠well, holding the button too long makes the ZigBee join fail. Geesh.
Unfortunately, though I got it to join my Z-Wave network, it doesnât seem to be participating in the mesh.
Perhaps itâs because Iâm on a V1 hub (non-Z-Wave Plus)? I donât particularly need a Z-Wave repeater at this location, but I have two more of these Iris Outlets that might go in locations where they could contribute to Z-WaveâŚ
Network repair for Z-Wave Repeater Iris: Desk Office [4F]: Failed to update mesh info
All zwave generations are backwards compatible. You can add a zwave plus Device to a zwave classic (fourth generation) controller and it will work fine, you just wonât get to take advantage of some of the newest features, in particular pair in place.
I have had success getting it to clear this error in one of two ways. First, the easy one. Just unplugging the outlet for 30 seconds. If that doesnât do it, then resetting the outlet and running replace in ST.
