I never use that settings, did you triple click the B button after the setup in app?
since last days a have a problem with the device handler.
the motion sensor did not recognise motion.
someone else?
@NewHere17 I donβt believe its a DH issue. Iβve had this issue often with a few of mine. Iβm also beginning to think its not a hardware issue either per say.
Iβve had another recent bout where the sensor was noting motion no problem and then decided to get stuck. I choose this time to ignore. It sorted itself out after many hours. Worked again fine and then decided to ignore motion. Waving, singing, dancing, flinging the cat motion, but nothing on the sensor (which i use to trigger lights).
This got me thinking of the what else is next that could be the issue and Iβm now leaning on environment/ atmosphere in the room ie heat, coldness. My sensor is in the room corner and close enough to the room vent which means my sensor gets a steady stream of outside air around it.
Whilst I can not prove my working theory (Iβve moved sensors from room to room)/its my current working theory and Iβm trying to monitor any common elements/attributes.
Notwithstanding the above, regardless of which DH you use (Iβve used then all) I do not believe that this issue is DH related at all.
Is there any way to display the temperature in the dashboard?
Display in which dashboard?
When I go to the SmartThings App, theres a main navigation point called βDashboardβ (lower left corner) where you can add your favorites. Or show the data as a tile.
I think that go with the main display of the sensor in the things tab & not something customizable without changing the code.
Hi @krlaframboise newbie here, looking to try out your Fibaro DTH at the same time Iβm trying to learn how to subscribe to UK Git Hub repositorys - can I do that with your code? If so, what owner/name/branch should I use? Or do I need to copy/paste the code manually?
@CSC - can you also tell me if I can subscribe to your repositiory? Iβm currently trying a few out to see what works for meβ¦
Apologies if Iβm not understanding how things work and my questions sound a little stupid!
Many thanks for your help and taking the time to create these DTHs
Think Iβve figured the github repository element out - I now have an italicised blue listing in my device handler menuβ¦ not sure if this is right?
Edit - got it all working now
I think you have to update from repo to sync the DTHs, but I could be wrong.
The settings for my repository are:
krlaframboise
SmartThings
master
Hi guys, need a little help with setting the senzor as thermostat and using it with google home.
I did changed the type to thermostat and linked to GH but every time I ask GH what is the inside temperature it gives me " thermostat is off and the temp is 19.5Β°C".
It looks like the senzor is not updating the temperature and also the βthermostat is offβ message is killing me.
Thank you!
Hi Chaps,
Im searching all over to see if anyone has any ideas about how to stop this sensor emitting any light? Its going in a bedroom so need it to be dark all night. Preferably by a mode or time setting?
Many thanks,
n
Set parameter 80 to inactive. 0.
Thanks Bob,
Figured my issue, itβs not syncing for some reason! Any ideas as to how you force sync?
N
If the DH you are using has a sync/config button on it in the ST app, put the Fibaro Device into config mode, press button B 3 times and it glows blue, and then press the sync/config button in the app.
EDIT: Change parameter 80 to 0 first.
hi, im using your handle and everything looks ok apart from it never always say "incomplete " after a sync, I left the logging running and got this, can you help?
It started syncing at 14:16 so to be getting errors so long after is a surprise
this is the 1st error
β14β:β25β:β35: error groovy.lang.MissingMethodException: No signature of method: script_dth_57bfb3fd_cf44_420e_be87_ef397f179319_ver_0_1.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport) values: [SensorBinaryReport(sensorValue: 255)]
Possible solutions: zwaveEvent(physicalgraph.zwave.commands.applicationstatusv1.ApplicationRejectedRequest), zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport), zwaveEvent(physicalgraph.zwave.commands.configurationv2.ConfigurationReport), zwaveEvent(physicalgraph.zwave.commands.crc16encapv1.Crc16Encap), zwaveEvent(physicalgraph.zwave.commands.deviceresetlocallyv1.DeviceResetLocallyNotification), zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.DeviceSpecificReport)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β25β:β35: debug Bathroom Motion N Temp - Parsed: SensorBinaryReport(sensorValue: 255)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β25β:β35: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 3003, payload: FF
14β:β58β:β27: error groovy.lang.MissingMethodException: No signature of method: script_dth_1da45e9c_af0d_4f70_900f_9a394dff16f3_ver_1_0000001.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.basicv1.BasicSet) values: [BasicSet(value: 0)]
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β58β:β27: debug Bathroom Motion N Temp - Parsed: BasicSet(value: 0)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β58β:β27: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 2001, payload: 00
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β58β:β27: error groovy.lang.MissingMethodException: No signature of method: script_dth_57bfb3fd_cf44_420e_be87_ef397f179319_ver_0_1.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport) values: [SensorBinaryReport(sensorValue: 0)]
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β58β:β27: debug Bathroom Motion N Temp - Parsed: SensorBinaryReport(sensorValue: 0)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β58β:β27: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 3003, payload: 00
d85f5b56-0dd5-4bee-8c16-ab2b95c1637c β14β:β58β:β10: debug Parsed zw device: 04, command: 600D, payload: 02 02 25 03 00 to MultiChannelCmdEncap(bitAddress: false, command: 3, commandClass: 37, destinationEndPoint: 2, parameter: [0], sourceEndPoint: 2) to null
d85f5b56-0dd5-4bee-8c16-ab2b95c1637c β14β:β58β:β10: debug MultiChannelCmdEncap mapped - [name:switch2, value:off]
d85f5b56-0dd5-4bee-8c16-ab2b95c1637c β14β:β58β:β10: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(bitAddress: false, command: 3, commandClass: 37, destinationEndPoint: 2, parameter: [0], sourceEndPoint: 2)
d85f5b56-0dd5-4bee-8c16-ab2b95c1637c β14β:β58β:β10: debug Event: zw device: 04, command: 600D, payload: 02 02 25 03 00
d85f5b56-0dd5-4bee-8c16-ab2b95c1637c β14β:β58β:β10: debug Parsed zw device: 04, command: 600D, payload: 01 01 25 03 00 to MultiChannelCmdEncap(bitAddress: false, command: 3, commandClass: 37, destinationEndPoint: 1, parameter: [0], sourceEndPoint: 1) to null
d85f5b56-0dd5-4bee-8c16-ab2b95c1637c β14β:β58β:β10: debug MultiChannelCmdEncap mapped - [name:switch1, value:off]
d85f5b56-0dd5-4bee-8c16-ab2b95c1637c β14β:β58β:β10: debug MultiChannelCmdEncap called - MultiChannelCmdEncap(bitAddress: false, command: 3, commandClass: 37, destinationEndPoint: 1, parameter: [0], sourceEndPoint: 1)
d85f5b56-0dd5-4bee-8c16-ab2b95c1637c β14β:β58β:β10: debug Event: zw device: 04, command: 600D, payload: 01 01 25 03 00
d85f5b56-0dd5-4bee-8c16-ab2b95c1637c β14β:β58β:β10: debug refresh() called
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β57β:β19: info Bathroom Motion N Temp - SensorMultilevelReport received, sensor: 3, scaledValue: 42
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β57β:β19: debug Bathroom Motion N Temp - Parsed: SensorMultilevelReport(precision: 0, scale: 1, scaledSensorValue: 42, sensorType: 3, sensorValue: [0, 42], size: 2)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β57β:β19: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 3105, payload: 03 0A 00 2A
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β57β:β16: error groovy.lang.MissingMethodException: No signature of method: script_dth_96f79474_49df_4bfc_9bb0_59b8a193742d_ver_0_1.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.basicv1.BasicSet) values: [BasicSet(value: 255)]
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β57β:β16: debug Bathroom Motion N Temp - Parsed: BasicSet(value: 255)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β57β:β16: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 2001, payload: FF
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β57β:β16: error groovy.lang.MissingMethodException: No signature of method: script_dth_0ff2e78d_afea_44fc_9802_cda7842d1d22_ver_0_2.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport) values: [SensorBinaryReport(sensorValue: 255)]
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β57β:β16: debug Bathroom Motion N Temp - Parsed: SensorBinaryReport(sensorValue: 255)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β57β:β16: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 3003, payload: FF
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β27β:β51: error groovy.lang.MissingMethodException: No signature of method: script_dth_614edf50_fbba_473c_a55b_6f52b02d4359_ver_0_1.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport) values: [SensorBinaryReport(sensorValue: 0)]
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β27β:β51: debug Bathroom Motion N Temp - Parsed: SensorBinaryReport(sensorValue: 0)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β27β:β51: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 3003, payload: 00
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β26β:β37: error groovy.lang.MissingMethodException: No signature of method: script_dth_8d0d0a81_dc08_4965_9228_96d80a430c24_ver_0_1.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.basicv1.BasicSet) values: [BasicSet(value: 255)]
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β26β:β37: debug Bathroom Motion N Temp - Parsed: BasicSet(value: 255)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β26β:β37: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 2001, payload: FF
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β26β:β37: error groovy.lang.MissingMethodException: No signature of method: script_dth_96f79474_49df_4bfc_9bb0_59b8a193742d_ver_0_1.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport) values: [SensorBinaryReport(sensorValue: 255)]
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β26β:β17: error groovy.lang.MissingMethodException: No signature of method: script_dth_614edf50_fbba_473c_a55b_6f52b02d4359_ver_0_1.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.basicv1.BasicSet) values: [BasicSet(value: 0)]
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β26β:β17: debug Bathroom Motion N Temp - Parsed: BasicSet(value: 0)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β26β:β17: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 2001, payload: 00
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β26β:β17: error groovy.lang.MissingMethodException: No signature of method: script_dth_96f79474_49df_4bfc_9bb0_59b8a193742d_ver_0_1.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport) values: [SensorBinaryReport(sensorValue: 0)]
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β26β:β17: debug Bathroom Motion N Temp - Parsed: SensorBinaryReport(sensorValue: 0)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β26β:β17: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 3003, payload: 00
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β25β:β35: error groovy.lang.MissingMethodException: No signature of method: script_dth_6f1dda24_e622_47d8_b780_48ff135686aa_ver_0_3.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.basicv1.BasicSet) values: [BasicSet(value: 255)]
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β25β:β35: debug Bathroom Motion N Temp - Parsed: BasicSet(value: 255)
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β25β:β35: debug Bathroom Motion N Temp - Parsing: zw device: 07, command: 2001, payload: FF
c04b00f4-55f7-45fb-8d11-1a13ee2f44de β14β:β25β:β35: error groovy.lang.MissingMethodException: No signature of method: script_dth_57bfb3fd_cf44_420e_be87_ef397f179319_ver_0_1.zwaveEvent() is applicable for argument types: (physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport) values: [SensorBinaryReport(sensorValue: 255)]
thanks
I am newbie⦠and I am trying to create a Fibaro Motion Sensor App.
I have selected βMy Smartappsβ, Create, selected βFrom Codeβ, pasted the source into the window, pressed CREATEβ¦ after which I receive following error and canβt continue:
No signature of method: script_app_metadata_8b6d2a21_8481_48cd_bdcc_71bb4a48c985.metadata() is applicable for argument types: (script_app_metadata_8b6d2a21_8481_48cd_bdcc_71bb4a48c985$_run_closure1) values: [script_app_metadata_8b6d2a21_8481_48cd_bdcc_71bb4a48c985$_run_closure1@35a92de2] Possible solutions: getMetadata(), getState(), setState(java.lang.Object), metaClass(groovy.lang.Closure)
Can anyone help me what to do�
If you are trying to use the code above you need to create this as a Device Type Handler, NOT a Smartapp.
Then you can save it OK.
Thank a lot
Chaps - any ideas on how to force a sync with this? Iβve tried pushing button once, three times and waitingβ¦ sync just doesnβt happen for some reason!
N
