I would have a time trigger at 10pm to set a variable to a value, either 0 or 1, or whatever you fancy, I’ll pick 1 for “enabled”.
IF
Time trigger happens at 10 pm >>> when true >>> set controlLight = 1
OR (
Motion changes to active
AND
Variable controlLight = 1
) >>> when true Using light, turn on
OR
Ask Alexa Macro "whatever macro turns the light off" was executed >>> when true >>> Set variable controlLight = 0
Piston restrictions prevent a piston from evaluating. An action restriction prevents the action from being scheduled.
The piston has three stages: Evaluation (when comparisons are made). Scheduling (when actions are decided and put into a queue). Execution (when actions queued during Scheduling are actually executed). Piston restrictions prevent all three stages. Action restrictions apply to the Scheduling stage.
Sweet! As much as I like all of this making bulletproof rules is seeming a bit tough, so I’m sure some solid ones are being generated by people with time to look into it more so it’d be nice to share anything decent I create too. Thanks so much @ady624. Good luck!
bamarayne
279
I wonder what is the best, most efficient, way to manage a switch. Simple use case: Assume a motion detector controlling a Z-Wave wall switch with several minutes of motion. Motion Active turns the switch ON, then Mutton Inactive turns the same switch OFF.
Is it better for the platform and for the switch, as something of a mechanical device, to repeatedly send an ON signal to it during the time of continuous motion? Or is it better for the piston to query the switch status and only turn it ON if it is OFF? Alternatively, how about setting a local piston variable to reflect the switch state and then check the variable state before turning the switch ON?
I too am torn as to which is the most efficient way to turn on a constantly toggling sensor and turn off after delay. As I am not the programmer I can’t say how much evaluation is going on for no result. I think that what you suggest in you second paragraph is already in place as the LATCH variant of the IF THEN.
i assume once this is latched in there is very little processing until a false redirects to the BUT IF.to reset the flip flop.
45 days into development, CoRE has reached BETA. Milestone 1 is all about optimizations, consolidation of existing features, optimizations and did I mention… optimizations?
@ady624 Can’t get Runtime Statistics to open, just get spinning wheel and then it times out and nothing happens. Been happening since approx 082, i think. I don’t often go into it so am unsure when it started. Am now on 1.090. Is it a CoRE issue?
Okay, I’m starting to feel like CoRE is beyond me, LOL. I just went to update to the latest version and I only show a version under the Obsolete section, nothing under the Conflicted or New. What the heck am I doing wrong?
