Hello @rey_rios, for your use case, just grab the ecobeeSetFanMinOnTime’s code at github under
P.S. You need to instantiate (rename) the smartapp for each comfort schedule (or program), so there will be ecobeeSetFanMinTimeAway, ecobeeSetFanMinTimeHome, ecobeesetFanMinTimeAwake, etc…
For each comfort schedule, you can then set a minimum Fan time per hour (in minutes) in the smartapp.
I am having trouble getting started with your myecobee integration. I am sure it is my error but when I click on the link https://graph.api.smartthings.com/ide/devices it tells me “Sorry, you’re not authorized to view this page.”
any help to get me past this is appreciated. Thanks for your time.
Thanks for pointing me in the right direction. Everything works fine now! I’m new to smarthings so the help is appreciated and a donation is on the way to you. Keep up the good work. On a side note If you ever have time to figure out a way to get Pentair smartlogic for my pool to work with smarthings I would make a nice donation for your efforts.
And then, Run ecobee3RemoteSensorInit on your smartphone/tablet
If any, please PM your errors in the logs by filtering them in the https://graph.api.smartthings.com/ide/logs screen by clicking on the ecobee3RemoteSensorInit smartapp or My Ecobee device in the section above.
And, provided that there is no smartapps that use them, you can delete them by clicking
on the ‘detete’ button at the bottom.
The ecobee3RemoteSensorInit works only with ecobee3 thermostats. It will show you
all your ecobee thermostats under ST, and you need to select the ecobee3 for which you
want to expose your remote sensors.
I’m sorry but It’s difficult for me to help you remotely without any trace.
So, I’d recommend to delete the ecobee3RemoteSensorInit smartapp and re-create it from scratch.
And, PM me the logs after the smartapp’s execution.
P.S. The smartapp is supposed to show you all your current thermostats (ecobee and not ecobee). You then
select the ecobee3 thermostat whose remote sensors you want to expose.
I’ve installed the “ecobeeControlPlug”, but I cannot get it to control my ecobee smartplug. I belive the SmartApp is not sending the congtrolPlug params in the correct order/format. Do you know how it should look? The SmartApp code itself was throwing some errors and after a bit of tinkering I get the errors to go away, but the plug does not go on/off/resume. In my “MyEcobee” events, I get this:
“controlPlug(Dehumidifier, off, indefinite) command was sent to MyEcobee”
Any help/insight anyone has is greatly appreciated.
Hi yvesracine,
I’ve try to use your WindowOrDoorOpen app. Would you adapt the app to use with more than one open/close sensor?
Thanks a lot for all your hard work!
