[Update] New Created Pistons only run if I use the Simulate Option.
Is Core Corrupted somehow?
No matter what condition I use, e.g
Motion Sensor is not active then
Send Notification ‘test’ in notifications page
Nothing works.
I have a light that I want to turn off based on motion sensor beign inactive.
The strange is that although the conditions are true the piston never fires.
Actually I would prefer that if Motion Sensor was not active for at least 5 minutes then
turn off light.
Try this, also instead of doing was inactive you can do inactive and then in the light condition you can put wait 5 min and turn light off. this would go between using closet light and turn off.
In the ST app, goto the motion sensor and then recent. See if the motion is actually cycling. Enable your Dashboard in the CoRE app and monitor the wait period so you can see whats going on. The motion has to be first triggered then go inactive in order for the wait to start counting.
