Need help getting Child atomicState value in Parent
In a child app the following atomicState is set as follows
atomicState.field = ‘12345678’
Then in the parent at a later time I want to get the atomicState.field value, it shows the atomicState object but when I try using it, a null error is thrown.
def childapps=findAllChildAppsByName(‘SHM Delay Child’)
childapps.each
log.debug "$it.simkeypad $it?.atomicState.field
// def obj=it?.atomicState.field
// obj.properties.each { k,v -> log.debug “$k $v”}
This
log.debug “$it.simkeypad $it?.atomicState.field”
generates this in live logging
pckeypad physicalgraph.app.InstalledSmartAppWrapper@6b34869?.atomicState.field
log.debug “$it.simkeypad ${it?.atomicState.field}”
generates an error
error java.lang.NullPointerException: Cannot get property ‘field’ on null object @line -1 (doCall)
Anyone know how to get the value of the child’s atomicState.field in a parent app?
Solved this by adding a function in the child app that is called from the parent app
In childapp
def getAtomic(field_name)
{return atomicState[field_name]} //allow parent to get atomic data from child
In parent app
def simKeypadDevices=findAllChildAppsByName(‘SHM Delay Simkypd Child’)
SimKeypadDevices.each
log.debug “$it.simkeypad ${it.getAtomic(‘field’)}”
Tagging @Jim here.
AFAIK that when a parent app calls a child device handler the return value cannot be relied upon as the ST design.
Jim does this hold true to parent/child apps also or can parent/child apps return values from methods reliably? If so is there is any restrictions on the return type?
Thank you for the response.
The child app is a SmartApp, not a DTH, and it’s been reliably working as described in my earlier post. I have read about the restriction with atomicState in a DTH
I don’t know the answer. Maybe @gausnes knows?
@RBoy is right, when you call get childDevices or childApps it isn’t the SmartApp / Device Handler but instead a InstalledSmartApp / Device that has a subset of the functionality exposed.
See for documentation on what that object does support
http://docs.smartthings.com/en/latest/ref-docs/installed-smart-app-wrapper-ref.html
