Multipurpose Sensor using Zigbee Contact MC Driver
Hi @Mariano_Colmenarejo,
I’ve been using your zigbee contact sensor driver for quite a while now and it’s been great. Today I opened the app to check on one of my garage sensors and I saw that the Received Signal Metrics box contains formatting information instead of data. Not that I use the data at all, I don’t even know what it means. But I thought you might like to know. See attached screenshot.
I’m not sure when this started, perhaps with the new firmware release? I can’t be sure because it’s been quite a while since I’ve opened the app.
This is a known issue affecting many different edge drivers and was caused by the most recent app update. It no longer supports HTML formatting from custom edge drivers. I don’t know if they’re intending to fix it or not, it’s very annoying. :rage:
Ok, thanks for the quick reply. Well, I was right that it was an update that broke it. Just the wrong update. :smiling_face:
Hi @allanp
I will fix the signal metrics as soon as I recover from the anger that caused me :confounded:, I already fixed it yesterday in some drivers
I am having the same issue with the Zigbee Motion Sensor MC driver. I am following this topic. Thanks @Mariano_Colmenarejo
All drivers that use signal Metrics capability have been fixed for about 8 hours, they will be updated automatically
Is the fix made for zigbee Aqara Water leak sensors also? It looks like my driver date is September 11, 2023.
I’ll fix it.
I think if you change to the Zigbee Moisture Sensor Mc controller your Aqara sensor would also work
Fixed in this driver version
 Name         Zigbee Aqara Water Leak Sensor Mc
 Version      2024-03-21T20:54:18.895923103
Thank you very much for fixing what Samsung broke. Your hard work is appreciated by community.
Yes! Looks like it’s working again. Thank you very much!
