Multiple hubaction commands in one function and parsing the response
thank you sooo much :smile:
it really works now.
Now I have to figure out how to parse the response and change the button state accordingly. Because the button stays “on” always.
That one is easy:
In your parse, once you decode your answer, you just have to create an event and send it to your tile.
Check my DTH: https://github.com/philippeportesppo/Honeywell_HPA250B_SmartThings/blob/master/honeywell-hpa250b.groovy
in the parse function, you’ll see how to do that.
Good luck
thanks. then difficult part is parsing :slight_smile:
actually, there’s one more question, since you know a lot about it.
I call several hubactions from the action:
def GuestWirelessOff() {
	log.debug "Executing 'GuestWirelessOff'"
return [authrouter1(), delayAction(9800), configStarted1(), delayAction1(9800), gwoff1(), delayAction2(9800), configFinished1(), delayAction3(9800)]
I just need to parse the result of gwoff1 to understand if it worked. How can I do that ?
I have no idea regarding the answer format you get but simply, parse method argument is a deacription string that can be either interpreted as json (my dth is an example) or html (you can refer to my airmentor dth on my same github) or other types as long as you have something to decode it.
Check the smartthings documentation for parse method, that will give you many examplea too
ok. I got it. I am able to parse the messages now. But response to “hubaction” does not trigger parse function.
Return to hubsoapaction triggers parse.
I don’t get it why.
I found this thread :
It says “put the port in hex with 4 digits” and I do that. my device id is C0A8FE01:0050
but doesnt work.
a comment on your implementation: all the events you returned will be fired at once in my understanding.
if you need to sequence -> action, you’ll have certainly to setup a state variable so that query to answer sequence update the state variable and plan the next sequence -> action
ok. I can do that. (state machine)
but I still could not get hubaction result to trigger parse
what can I check ?
whatever I do , I could not make the result of hubaction command to trigger parse()
hubsoap action command results always trigger parse()
I compared both results and can’t find a significant difference to prevent response reaching the hub.
this is an example reaching the parse function:
POST /soap/server_sa/ HTTP/1.1
Accept: */*
User-Agent: Linux UPnP/1.0 SmartThings
Host: 192.168.254.1:80
CONNECTION: keep-alive
SOAPAction: "urn:NETGEAR-ROUTER:service:DeviceConfig:1#ConfigurationStarted"
Content-Type: text/xml; charset="utf-8"
Content-Length: 343
<?xml version="1.0" encoding="utf-8"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:ConfigurationStarted xmlns:u="urn:NETGEAR-ROUTER:service:DeviceConfig:1"><NewSessionID>58DEE6006A88A967E89A</NewSessionID></u:ConfigurationStarted></s:Body></s:Envelope>HTTP/1.0 200 OK
CONTENT-LENGTH: 359
CONTENT-TYPE: text/xml; charset="utf-8"
SERVER: Linux UPnP/1.0
<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
  <s:Body>
    <m:ConfigurationStartedResponse xmlns:m="urn:NETGEAR-ROUTER:service:DeviceConfig:1"></m:ConfigurationStartedResponse>
    <ResponseCode>000</ResponseCode>
  </s:Body>
</s:Envelope>
and this is the one from hubaction , which does not trigger parse:
POST /soap/server_sa/ HTTP/1.0
SOAPAction: "urn:NETGEAR-ROUTER:service:WLANConfiguration:1#GetGuestAccessEnabled"
content-type: text/xml;charset=utf-8
User-Agent: SOAP Toolkit 3.0
connection: keep-Alive
Cache-Control: no-cache
Pragma: no-cache
content-length: 599
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<SOAP-ENV:Envelope xmlns:SOAPSDK1="http://www.w3.org/2001/XMLSchema" xmlns:SOAPSDK2="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAPSDK3="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Header>
<SessionID>58DEE6006A88A967E89A</SessionID>
</SOAP-ENV:Header><SOAP-ENV:Body>
<M1:GetGuestAccessEnabled xmlns:M1="urn:NETGEAR-ROUTER:service:WLANConfiguration:1"></M1:GetGuestAccessEnabled>
</SOAP-ENV:Body></SOAP-ENV:Envelope>HTTP/1.0 200 OK
CONTENT-LENGTH: 569
<?xml version="1.0" encoding="UTF-8"?><SOAP-ENV:Envelope xmlns:SOAPSDK1="http://www.w3.org/2001/XMLSchema" xmlns:SOAPSDK2="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAPSDK3="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
  <SOAP-ENV:Body>
    <m:GetGuestAccessEnabledResponse xmlns:m="urn:NETGEAR-ROUTER:service:WLANConfiguration:1">
      <NewGuestAccessEnabled>0</NewGuestAccessEnabled>
    </m:GetGuestAccessEnabledResponse>
  </SOAP-ENV:Body>
I also tried making the soap headers similar to the hubsoapaction headers:
Pragma: no-cache
content-length: 599
<SOAP-ENV:Header>
CONTENT-LENGTH: 569
  <SOAP-ENV:Body>
  </SOAP-ENV:Body>
I really can’t understand why this does not trigger parse()
desparately looking for help…
few possibilities:
  1. the event is not fired. send it explicitely
  2. the answer is sent back to a wrong instance. For this one, open the live logging and check if you don’t see 2 instances of your device. If not, maybe you can try to change the IP address to another value. There is a bug known as ghost device. I am not sure if this is solved now.
  3. make sure you don’t have the simulator on. Go to the IDE and check the device handler view. there should not be anything in the similator cell
hope it helps
the event is fired. because I get the packet on my router and it responds. I also see the packet back to the ST Hub.
I only have one instance of “Rouer” in live logging.
simulator is not on.
this might be something related to the device ID setting but I set it correctly , “C0A8FE01:0050” for “192.168.254.1:80”
so what else could it be ?
i faced that because the hub was sending the answer to a ghost instance. Try to change the IP address of the device and the networkid
the device is the router. changing its IP is not easy because I have more than 30 devices connected to it.
and if it was a ghost device then how does hubsoapaction work ?
i don’t use hubsoap so i cannot comment. you can search for my post about this hub ghost stuff on the forum. i am on my phone so i cannot be very helpful.
will try to check something once back home but yesterday i thought you said you got the parse called so i am getting confused now.
are you bursting hubactions and only receive the first one or nothing works anymore ?
In my original code I am calling several hubsoapactions and 1 hubaction sequentially.
but for testing purpose , I call only one of them.
I see the packet go to the router and it replies.
but parse is not triggered.
most probably because of some addressing issue.
when I had found this (below) , I had thought that it was the reason. But it is not…
In my case I use:
  private String convertIPtoHex(ipAddress) {
        String hex = ipAddress.tokenize( '.' ).collect {  String.format( '%02x', it.toInteger() ) }.join()
        log.debug "IP address entered is $ipAddress and the converted hex code is $hex"
        return hex
private String convertPortToHex(port) {
	String hexport = port.toString().format( '%04x', port.toInteger() )
    log.debug hexport
    return hexport
So the hexa address in my logs is:
IP address entered is 192.168.1.49 and the converted hex code is c0a80131
and what I have in my device is also lowercase hexa
I am saying this since I see a guy in the post you refer talking about upper/lower case. Maybe they just have to be consistent to work…
ok. I got your point. But there is no hex format of IP address in my code. I just have the hex format IP address in the device settings.
So there’s nothing to match right ?
I’ll try with lower case just to make sure…
edit: tried with lowercase but still the same…
I think that’s now over what I have experienced when developing my own things. I have no further idea for now
thanks. maybe I need idea from someone who knows the internals of hubaction and hubsoapaction commands.
on which sub-forum should I post it to ?
finally I managed to solve the problem. I used a semi-raw version of the hubaction command. Full code of the device handler is below.
I just have one issue now; I want to refresh the status of router settings when the device is updated.
But I need to run multiple hubaction commands for this.
So I put the commands in the refreshCmd() function which is called through updated()
However, the format "return [command1(), command2()] does not work there.
when I bind a similar function to a button , this format works.
what is the problem here ?
 *  Netgear Router
 *  Copyright 2017 ilker Aktuna
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
//import groovy.json.JsonSlurper
metadata {
	definition (name: "Netgear Router", namespace: "ilkeraktuna", author: "ilker Aktuna") {
		capability "Switch"
		attribute "ip", "string"
		attribute "port", "string"
		attribute "username", "string"
		attribute "password", "string"
        attribute "GuestWifi2Ghz", "string"
        attribute "GuestWifi5Ghz", "string"
        attribute "5ghz", "string"
        attribute "2ghz", "string"
		command "GuestWirelessOn"
		command "GuestWirelessOff"
        command "GuestWirelessOn5"
		command "GuestWirelessOff5"
        command "GetAll"
    preferences {
    	section {
        input title: "", description: "Netgear Router Control", displayDuringSetup: true, type: "paragraph", element: "paragraph"
        input("ip", "string", title:"LAN IP address", description: "LAN IP address", required: true, displayDuringSetup: true)
        input("port", "string", title:"LAN Port", description: "LAN Port", required: true, displayDuringSetup: true)
        input("username", "string", title:"Administrator username (case sensitive)", description: "Administrative rights username (case sensitive)", required: true, displayDuringSetup: true)
        input("password", "password", title:"password (case sensitive)", description: "password (case sensitive)", required: false, displayDuringSetup: true)
	simulator {
		// TODO: define status and reply messages here
	// UI tile definitions
	tiles(scale: 2) {
		standardTile("GuestWifi5Ghz","device.GuestWifi5Ghz", decoration: "flat", width: 2, height: 2, canChangeIcon: true){
				state "on", label: 'GuestWifi5Ghz\n${name}', action: "GuestWirelessOff5", icon: "st.Kids.kids15", backgroundColor: "#79b821", nextState: "turningOff"
				state "off", label: 'GuestWifi5Ghz\n${name}', action: "GuestWirelessOn5", icon: "st.Kids.kids15", backgroundColor: "#ffffff", nextState: "turningOn"
				state "turningOn", label: 'GuestWifi5Ghz\n${name}', action: "GuestWirelessOff5", icon: "st.Kids.kids15", backgroundColor: "#79b821", nextState: "turningOff"
				state "turningOff", label: 'GuestWifi5Ghz\n${name}', action: "GuestWirelessOn5", icon: "st.Kids.kids15", backgroundColor: "#ffffff", nextState: "turningOn"
		standardTile("GuestWifi2Ghz","device.GuestWifi2Ghz", decoration: "flat", width: 2, height: 2){
				state "on", label: 'GuestWifi2Ghz\n${name}', action: "GuestWirelessOff", icon: "st.Kids.kids15", backgroundColor: "#79b821", nextState: "turningOff"
				state "off", label: 'GuestWifi2Ghz\n${name}', action: "GuestWirelessOn", icon: "st.Kids.kids15", backgroundColor: "#ffffff", nextState: "turningOn"
				state "turningOn", label: 'GuestWifi2Ghz\n${name}', action: "GuestWirelessOff", icon: "st.Kids.kids15", backgroundColor: "#79b821", nextState: "turningOff"
				state "turningOff", label: 'GuestWifi2Ghz\n${name}', action: "GuestWirelessOn", icon: "st.Kids.kids15", backgroundColor: "#ffffff", nextState: "turningOn"
		standardTile( "refresh", "device.power", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
        valueTile("5ghz", "device.5ghz", decoration: "flat", width: 2, height: 2) {
			state ("default", label:'${currentValue}')
        valueTile("2ghz", "device.2ghz", decoration: "flat", width: 2, height: 2) {
		standardTile( "refreshall", "device.power", decoration: "flat", width: 2, height: 2) {
			state "default", label:'refresh', action: "GetAll", icon:"st.secondary.refresh", nextState: "default"
		main "GuestWifi2Ghz"
		details(["GuestWifi5Ghz","GuestWifi2Ghz","refresh","5ghz","2ghz","refreshall"])
def installed() {
    initialize()
def updated() {
//    unsubscribe()
    initialize()
def poll(){
    refreshCmd()
def initialize() {
    refreshCmd()
	def events = []
    def descMap = parseDescriptionAsMap(description)
	def body = new String(descMap["body"].decodeBase64())
    log.debug body
    def xmlt = new groovy.util.XmlParser().parseText(body)
    if ( state.lastcmd == "gwget") {
	log.debug xmlt.'*'.'*'.NewGuestAccessEnabled.text()
    if (xmlt.'*'.'m:GetGuestAccessEnabledResponse'.NewGuestAccessEnabled.text() == "1") {sendEvent(name: "GuestWifi2Ghz", value: "on", isStateChange: true, displayed: false)}
    if (xmlt.'*'.'m:GetGuestAccessEnabledResponse'.NewGuestAccessEnabled.text() == "0") {sendEvent(name: "GuestWifi2Ghz", value: "off", isStateChange: true, displayed: false)}
    if (xmlt.'*'.'m:GetGuestAccessNetworkInfoResponse'.NewSSID.text() != null) {
    state.ssid2 = xmlt.'*'.'m:GetGuestAccessNetworkInfoResponse'.NewSSID.text()
    sendEvent(name: "2ghz", value: state.ssid2, isStateChange: true, displayed: false)
    log.debug "ssid 2ghz: $state.ssid"}
    if ( state.lastcmd == "gwget5") {
    if (xmlt.'*'.'m:Get5GGuestAccessEnabledResponse'.NewGuestAccessEnabled.text() == "1") {sendEvent(name: "GuestWifi5Ghz", value: "on", isStateChange: true, displayed: false)}
    if (xmlt.'*'.'m:Get5GGuestAccessEnabledResponse'.NewGuestAccessEnabled.text() == "0") {sendEvent(name: "GuestWifi5Ghz", value: "off", isStateChange: true, displayed: false)}
    if (xmlt.'*'.'m:Get5GGuestAccessNetworkInfoResponse'.NewSSID.text() != null) {
    state.ssid5 = xmlt.'*'.'m:Get5GGuestAccessNetworkInfoResponse'.NewSSID.text()
    sendEvent(name: "5ghz", value: state.ssid5, isStateChange: true, displayed: false)
    log.debug "ssid 5ghz000: $state.ssid5"}
    if ( state.lastcmd == "gwgetall") {
    if ( state.lastcmd == "getall") {
    if (xmlt.'*'.'m:Get5GGuestAccessNetworkInfoResponse'.NewSSID.text() != null && xmlt.'*'.'m:Get5GGuestAccessNetworkInfoResponse'.NewSSID.text() != "") {
    state.ssid5 = xmlt.'*'.'m:Get5GGuestAccessNetworkInfoResponse'.NewSSID.text() + "\n" + xmlt.'*'.'m:Get5GGuestAccessNetworkInfoResponse'.NewKey.text()
    sendEvent(name: "5ghz", value: "$state.ssid5", isStateChange: true, displayed: false)
    log.debug "ssid 5ghz: $state.ssid5"}
    if (xmlt.'*'.'m:GetGuestAccessNetworkInfoResponse'.NewSSID.text() != null && xmlt.'*'.'m:GetGuestAccessNetworkInfoResponse'.NewSSID.text() != "") {
    state.ssid2 = xmlt.'*'.'m:GetGuestAccessNetworkInfoResponse'.NewSSID.text() + "\n" + xmlt.'*'.'m:GetGuestAccessNetworkInfoResponse'.NewKey.text()
    sendEvent(name: "2ghz", value: "$state.ssid2", isStateChange: true, displayed: false)
    log.debug "ssid 2ghz: $state.ssid2"}
def parseDescriptionAsMap(description) {
	description.split(",").inject([:]) { map, param ->
		def nameAndValue = param.split(":")
        if (nameAndValue.length == 2) map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
        else map += [(nameAndValue[0].trim()):""]
// handle commands
def on() {
	log.debug "Executing 'on'"
	// TODO: handle 'on' command
def off() {
	log.debug "Executing 'off'"
	// TODO: handle 'off' command
def GuestWirelessOn5() {
	log.debug "Executing 'GuestWirelessOn 5Ghz'"
return [authrouter(), delayAction(9000), configStarted(), delayAction(9000), gwon5(), delayAction(9000), configFinished(), delayAction(9000), gwget5(), delayAction(9000), gwinfo5()]
def GuestWirelessOff5() {
	log.debug "Executing 'GuestWirelessOff 5Ghz'"
return [authrouter(), delayAction(9800), configStarted(), delayAction(9800), gwoff5(), delayAction(9800), configFinished(), delayAction(9000), gwget5()]
def GuestWirelessOn() {
	log.debug "Executing 'GuestWirelessOn 2Ghz'"
return [authrouter(), delayAction(9000), configStarted(), delayAction(9000), gwon(), delayAction(9000), configFinished(), delayAction(9000), gwget(), delayAction(9000), gwinfo()]
	log.debug "Executing 'GuestWirelessOff 2Ghz'"
return [authrouter(), delayAction(9800), configStarted(), delayAction(9800), gwoff(), delayAction(9800), configFinished(), delayAction(9000), gwget()]
def refreshCmd() {
	log.debug "Executing refreshCmd"
    def host = ip
    def port = port
    def hosthex = convertIPtoHex(host)
    def porthex = convertPortToHex(port)
    log.debug "The device id before update is: $device.deviceNetworkId"
    device.deviceNetworkId = "$hosthex:$porthex"
    log.debug "The device id configured is: $device.deviceNetworkId"
    //return gwgetall()
    //return infoall
    return GetAll()
//    return [gwget(), delayAction(1000), gwget5(), delayAction(1000), gwinfo(), delayAction(1000), gwinfo5()]
def GetAll() {
	state.lastcmd = "getall"
private gwgetall() {
	state.lastcmd = "gwgetall"
	def host = "$ip:$port"
    def method = "POST"
    def path = "/soap/server_sa/"
    def headers = [:]
    headers.put("HOST", "$host")
    headers.put("SOAPAction", "urn:NETGEAR-ROUTER:service:WLANConfiguration:1#GetGuestAccessEnabled")
	headers.put("content-type", "text/xml;charset=utf-8")
    try {
    def body="""<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<SOAP-ENV:Header>
</SOAP-ENV:Body></SOAP-ENV:Envelope>"""
    def hubAction = new physicalgraph.device.HubAction(
    	method: method,
    	path: path,
    	headers: headers,
        body: body
    hubAction
    catch (Exception e) {
    	log.debug "Hit Exception $e on $hubAction"
    log.debug "------------1"
    new physicalgraph.device.HubAction("delay 2000")
    log.debug "------------2"
    headers.put("SOAPAction", "urn:NETGEAR-ROUTER:service:WLANConfiguration:1#Get5GGuestAccessEnabled")
    try {
<SOAP-ENV:Header>
<M1:Get5GGuestAccessEnabled xmlns:M1="urn:NETGEAR-ROUTER:service:WLANConfiguration:1"></M1:Get5GGuestAccessEnabled>
    	method: method,
    	path: path,
    	headers: headers,
        body: body
    hubAction
private gwoff() {
    def method = "POST"
    def headers = [:]
    headers.put("SOAPAction", "urn:NETGEAR-ROUTER:service:WLANConfiguration:1#SetGuestAccessEnabled")
    try {
    def body="""<?xml version="1.0" encoding="UTF-8" standalone="no"?><SOAP-ENV:Envelope xmlns:SOAPSDK1="http://www.w3.org/2001/XMLSchema" xmlns:SOAPSDK2="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAPSDK3="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Header>
</SOAP-ENV:Header>
<SOAP-ENV:Body>
<M1:SetGuestAccessEnabled xmlns:M1="urn:NETGEAR-ROUTER:service:WLANConfiguration:1">
</M1:SetGuestAccessEnabled>
</SOAP-ENV:Body>
    	method: method,
    	path: path,
    	headers: headers,
        body: body
    hubAction
private gwon() {
    def method = "POST"
    def headers = [:]
    headers.put("SOAPAction", "urn:NETGEAR-ROUTER:service:WLANConfiguration:1#SetGuestAccessEnabled2")
    try {
<SOAP-ENV:Header>
<M1:SetGuestAccessEnabled2 xmlns:M1="urn:NETGEAR-ROUTER:service:WLANConfiguration:1">
<NewGuestAccessEnabled>1</NewGuestAccessEnabled>
</M1:SetGuestAccessEnabled2>
    	method: method,
    	path: path,
    	headers: headers,
        body: body
    hubAction
private gwget() {
	state.lastcmd = "gwget"
    def method = "POST"
    def headers = [:]
    try {
<SOAP-ENV:Header>
    	method: method,
    	path: path,
    	headers: headers,
        body: body
    hubAction
private gwinfo() {
    def method = "POST"
    def headers = [:]
    headers.put("SOAPAction", "urn:NETGEAR-ROUTER:service:WLANConfiguration:1#GetGuestAccessNetworkInfo")
    try {
<SOAP-ENV:Header>
<M1:GetGuestAccessNetworkInfo xmlns:M1="urn:NETGEAR-ROUTER:service:WLANConfiguration:1"></M1:GetGuestAccessNetworkInfo>
    	method: method,
    	path: path,
    	headers: headers,
        body: body
    hubAction
private gwoff5() {
    def method = "POST"
    def headers = [:]
    headers.put("SOAPAction", "urn:NETGEAR-ROUTER:service:WLANConfiguration:1#Set5GGuestAccessEnabled")
    try {
<SOAP-ENV:Header>
</SOAP-ENV:Header>
<SOAP-ENV:Body>
<M1:Set5GGuestAccessEnabled xmlns:M1="urn:NETGEAR-ROUTER:service:WLANConfiguration:1">
</M1:Set5GGuestAccessEnabled>
</SOAP-ENV:Body>
    	method: method,
    	path: path,
    	headers: headers,
        body: body
    hubAction
private gwon5() {
    def method = "POST"
    def headers = [:]
    headers.put("SOAPAction", "urn:NETGEAR-ROUTER:service:WLANConfiguration:1#Set5GGuestAccessEnabled2")
    try {
<SOAP-ENV:Header>
<M1:Set5GGuestAccessEnabled2 xmlns:M1="urn:NETGEAR-ROUTER:service:WLANConfiguration:1">
</M1:Set5GGuestAccessEnabled2>
    	method: method,
    	path: path,
    	headers: headers,
        body: body
    hubAction
private gwget5() {
	state.lastcmd = "gwget5"
    def method = "POST"
    def headers = [:]
    try {
<SOAP-ENV:Header>
    	method: method,
    	path: path,
    	headers: headers,
        body: body
    hubAction
private gwinfo5() {
    def method = "POST"
    def headers = [:]
    headers.put("SOAPAction", "urn:NETGEAR-ROUTER:service:WLANConfiguration:1#Get5GGuestAccessNetworkInfo")
    try {
<SOAP-ENV:Header>
<M1:Get5GGuestAccessNetworkInfo xmlns:M1="urn:NETGEAR-ROUTER:service:WLANConfiguration:1"></M1:Get5GGuestAccessNetworkInfo>
    	method: method,
    	path: path,
    	headers: headers,
        body: body
    hubAction
private authrouter() {
def hubaction
        	try {
    hubaction = new physicalgraph.device.HubSoapAction(
	path:    "/soap/server_sa/",
	urn:     'urn:NETGEAR-ROUTER:service:ParentalControl:1',
	action:  "Authenticate",
	body:    ["NewPassword":"$password", "NewUsername":"$username" ],
	headers: [Host:"$host", CONNECTION: "close"]
        log.debug e
    return hubaction
private configStarted() {
state.lastcmd = "configStarted"
def hubaction
            try {
	urn:     'urn:NETGEAR-ROUTER:service:DeviceConfig:1',
	action:  "ConfigurationStarted",
	body:    ["NewSessionID":"58DEE6006A88A967E89A" ],
	headers: [Host:"$host", CONNECTION: "keep-alive"]
        log.debug e
    return hubaction
private configFinished() {
state.lastcmd = "configFinished"
def hubaction
            try {
	action:  "ConfigurationFinished",
	body:    ["NewStatus":"ChangesApplied" ],
        log.debug e
    return hubaction
private delayAction(long time) {
	new physicalgraph.device.HubAction("delay $time")
    return hex
    log.debug hexport
    return hexport
//bunlar lazım mı
// gets the address of the Hub
private getCallBackAddress() {
    return device.hub.getDataValue("localIP") + ":" + device.hub.getDataValue("localSrvPortTCP")
// gets the address of the device
private getHostAddress() {
    def ip = getDataValue("ip")
    def port = getDataValue("port")
    if (!ip || !port) {
        def parts = device.deviceNetworkId.split(":")
        if (parts.length == 2) {
            ip = parts[0]
            port = parts[1]
        } else {
            log.warn "Can't figure out ip and port for device: ${device.id}"
    log.debug "Using IP: $ip and port: $port for device: ${device.id}"
    return convertHexToIP(ip) + ":" + convertHexToInt(port)
private Integer convertHexToInt(hex) {
    return Integer.parseInt(hex,16)
private String convertHexToIP(hex) {
    return [convertHexToInt(hex[0..1]),convertHexToInt(hex[2..3]),convertHexToInt(hex[4..5]),convertHexToInt(hex[6..7])].join(".")
